"Not Found Device!" on Livesuit... Anyone have this?
I'm stuck in a bootloop and would like to reflash back to stock. Ive downloaded shawn's stock image and i have livesuit from the same thread. The drivers are installed.. when I hold menu and plug USB in, my tab is recognized as an ADB interface device... But Im unable to get livesuit to detect it.... Ive tried it on a different computer (32 bit vista) to the same result...Tags: None
Originally posted by ratjr15 View PostI'm stuck in a bootloop and would like to reflash back to stock. Ive downloaded shawn's stock image and i have livesuit from the same thread. The drivers are installed.. when I hold menu and plug USB in, my tab is recognized as an ADB interface device... But Im unable to get livesuit to detect it.... Ive tried it on a different computer (32 bit vista) to the same result...
I run livesuite first and select the image I want loaded on my tablet. Then I press and hold power and the menu button together for about 30-45 seconds. Next plug in the usb cable. You will hear a usb device connect and livesuite should automatically start working. It will prompt you and ask if you want to format the device or just flash. I just flash. When its finished it pops up a window that looks like an error message, you hear the usb device disconnect and your tablet restarts.
Hope this helps.
By the way...
You did see the video I posted on youtube I assume.
The procedure we are following is here:http://www.cidtux.com/1/post/2012/1/how-to-flashupgrade-onda-vx580wvx610w-deluxe-to-android-ice-cream-sandwich-403-fir...
The biggest things I have noticed are you must remove any SD cards. The tablet must be off when you plug it in after you have Live Suite ready. The easiest way I have found to make sure is if you have the tablet plugged in to the USB and hit the power button, usually 20-30 seconds, you will hear the microsoft USB disconnected sound. now it is off. Now try unplugging the USB, load up Livesuite (I think I have been using the Version 1.07 that was packaged up with the Onda firmwares) and start the procedure.
There are currently 8968 users online. 4 members and 8964 guests.
