Thank you,
How to flash without OTG?
Both the OTG and Power Supply Port on my MX1 were broken long time ago. I am currently powering it through the USB port with a powered USB hub. I just want to get prepared in case I need to flash it again. Is it possible to flash it without the OTG port?
Thank you,Tags: None
Assuming its an rk processor then Within limits if you have clockwork recovery then yes. If you are rooted and a clockwork recovery is available for your device then you shod be able to first install clockwork and then flash.
Limits, then new images must be compatible with your current ROM.
From a safety point of view you would need a recovery with embedded kernel.
Sent from my XT890 using Tapatalk900Supersport
freaktab developer
Originally posted by 900supersport View PostAssuming its an rk processor then Within limits if you have clockwork recovery then yes. If you are rooted and a clockwork recovery is available for your device then you shod be able to first install clockwork and then flash.
No I use clockwork recovery to flash updates to my ROMs on my tablets. saves me having to boot to windows.900Supersport
freaktab developer
What device do you have and is it rooted?
freaktab developer
I think leolas has probably done a clockwork recovery for that. if so you should be able to download to the device and then flsh it from a terminal session. it should then be possible to flash an updated ROM.900Supersport
freaktab developer
Originally posted by 900supersport View PostI think leolas has probably done a clockwork recovery for that. if so you should be able to download to the device and then flsh it from a terminal session. it should then be possible to flash an updated ROM.
I will look into details. Appreciate all your advice and patience.
There are currently 2712 users online. 5 members and 2707 guests.
