Got myself a TP-LINK TL-WN723N V3 WiFi dongle (realtek RTL8188eu chipset), cause the build in is too slow, only 65Mbit.
My setup is as follows:
ROM: Hybrid FW V2.2.3 1080p by Lewy!
Kernel: 2dark4u 1.4 1080p
Here's what i've managed to do:
Found on the web 8188eu.ko driver module and then fired up a shell console...
root@android:/ # insmod /sdcard/rtl8188eu/8188eu.ko root@android:/ # lsmod 8188eu 529790 0 Live 0x00000000 root@android:/ # dmesg <4>[ 334.567035] <==== _ReadAdapterInfo8188EU in 140 ms <4>[ 334.567983] rtw_register_early_suspend <4>[ 334.568106] rtw_macaddr_cfg MAC Address = f8:1a:67:0c:b4:6d <4>[ 334.568126] MAC Address from pnetdev> dev_addr= f8:1a:67:0c:b4:6d <4>[ 334.576260] bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0 <6>[ 334.577339] usbcore: registered new interface driver rtl8188eu root@android:/ # netcfg lo UP 127.0.0.1/8 0x00000049 00:00:00:00:00:00 tunl0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 sit0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 ip6tnl0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 wlan0 UP 192.168.0.104/24 0x00001043 00:22:f4:62:0c:4e wlan1 DOWN 0.0.0.0/0 0x00001002 00:00:00:00:00:00 root@android:/ # ifconfig wlan1 up root@android:/ # netcfg lo UP 127.0.0.1/8 0x00000049 00:00:00:00:00:00 tunl0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 sit0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 ip6tnl0 DOWN 0.0.0.0/0 0x00000080 00:00:00:00:00:00 wlan0 UP 192.168.0.104/24 0x00001043 00:22:f4:62:0c:4e wlan1 UP 0.0.0.0/0 0x00001043 00:00:00:00:00:00 root@android:/ # iwlist wlan1 scan root@android:/ # iwconfig wlan1 essid name key xxx 250|root@android:/ # dhcpcd d wlan1 dhcpcd[2755]: version 5.2.10 starting dhcpcd[2755]: wlan1: using hwaddr 00:00:00:00:00:00 dhcpcd[2755]: wlan1: executing `/system/etc/dhcpcd/dhcpcdrunhooks', reason PREINIT dhcpcd[2755]: wlan1: executing `/system/etc/dhcpcd/dhcpcdrunhooks', reason CARRIER dhcpcd[2755]: wlan1: broadcasting for a lease dhcpcd[2755]: wlan1: sending DISCOVER (xid 0xf6631179), next in 4.03 seconds dhcpcd[2755]: wlan1: sending DISCOVER (xid 0xf6631179), next in 7.12 seconds dhcpcd[2755]: wlan1: sending DISCOVER (xid 0xf6631179), next in 16.93 seconds dhcpcd[2755]: wlan1: sending DISCOVER (xid 0xf6631179), next in 32.62 seconds dhcpcd[2755]: timed out dhcpcd[2755]: allowing 8 seconds for IPv4LL timeout dhcpcd[2755]: wlan1: probing for an IPv4LL address dhcpcd[2755]: wlan1: checking for 169.254.130.110 dhcpcd[2755]: wlan1: sending ARP probe (1 of 3), next in 1.80 seconds dhcpcd[2755]: wlan1: sending ARP probe (2 of 3), next in 1.90 seconds dhcpcd[2755]: wlan1: sending ARP probe (3 of 3), next in 2.00 seconds dhcpcd[2755]: wlan1: using IPv4LL address 169.254.130.110 dhcpcd[2755]: wlan1: adding IP address 169.254.130.110/16 dhcpcd[2755]: wlan1: adding route to 169.254.0.0/16 dhcpcd[2755]: wlan1: writing lease `/data/misc/dhcp/dhcpcdwlan1. lease' dhcpcd[2755]: wlan1: executing `/system/etc/dhcpcd/dhcpcdrunhooks', reason IPV4LL dhcpcd[2755]: forking to background dhcpcd[2755]: forked to background, child pid 2786 WPA2PSK AES
ONLY FROM SHELL:
Now it scans through all available networks just fine, but when I'm trying to connect
to my wifi network secured with WPA2PSK AES it won't aquire a static dhcp ip address,
it gets instead a private one which is weared...
FROM Android Wifi settings:
Won't turn on at all!
What am I doing wrong?
