QC802 Bricked - Errors log from serial console
    My QC802 got bricked. I have a small progress. The device somehow started to respond on USB port with VID=2207 and PID=310B, so I quickly found and install proper drivers (rockusb.inf).
    However:
    1) when I try to flash the device with (NEOTV CROM Flash Tool 1.37) I get the following error:
    Test device failed
    at the same time on the serial console:
    ▒RK310B▒▒RK310B▒▒RK310B▒▒RK310B▒▒RK310B▒DDR Version 1.04 20130517
    In
    DDR3
    300MHz
    Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=8 Size=2048MB
    Memory OK
    OUT
    serial_init 3
    ChipType = 3
    ...FlashInit enter...
    FtlMallocOffset = 8040
    FtlMallocOffset = 10040
    FtlMallocOffset = 11040
    ...NandcInit enter...
    gNandcVer = 6
    2) when I try to flash the device with (Rockchip Batch Tool v1.7) I get the following error:
    19:15:47 928 Rockchip Batch Tool v1.7.1.1 start run
    19:15:57 111 **********Restore Start Total<1>**********
    19:15:57 113 <Layer 6-2> Download Boot Start
    19:15:59 662 <Layer 6-2> Download Boot Success
    19:15:59 663 <Layer 6-2> Wait For Maskrom Start
    19:16:00 113 <Layer 6-2> Wait For Maskrom Success
    19:16:00 114 <Layer 6-2> Test Device Start
    19:16:00 116 <Layer 6-2> Test Device Success
    19:16:00 118 <Layer 6-2> Check Chip Start
    19:16:00 120 <Layer 6-2> Check Chip Success
    19:16:00 122 <Layer 6-2> Get FlashInfo Start
    19:16:00 123 <LAYER 6-2> INFO:FlashInfo: 0 0 0 0 0 4 10 0 32 0 0
    19:16:00 124 <Layer 6-2> Get FlashInfo Success
    19:16:00 128 <Layer 6-2> Prepare IDB Start
    19:16:00 129 <LAYER 6-2> ERROR:PrepareIDB-->No Found 1st Flash CS
    19:16:00 131 <Layer 6-2> Prepare IDB Fail
    19:16:00 133 **********Restore Done Success<0> Fail<1> Time<3027>ms**********
    In
    DDR3
    300MHz
    Memory OK
    OUT
    serial_init
    UsbBoot
    StorageInit
    AccessTime = 50 ns , CycleTiming = 7 ns FMWAIT @0x1082
    No.1 FLASH INFO:ff ff ff ff ff ff
    No.2 FLASH INFO:ff ff ff ff ff ff
    No.3 FLASH INFO:ff ff ff ff ff ff
    No.4 FLASH INFO:ff ff ff ff ff ff
    SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1907
    SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1907
    SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1907
    SDC_BusRequest: CMD=1 SDC_RESP_TIMEOUT 1907
    ERROR:Card Identify Failed 20
    Spi_ChipId = ffffff
    UsbHook
    Does it mean that my flash/rom memory got broken?? I would greatly appreciate any help :-)
