plese help
Originally posted by peety View PostNot being a sa.. But, is this your first android device? Depending on launcher you use. You should be able to just long press on the widget and drag it off screen to delete. To add new. Open app drawer and swipe or press on widget to select it. Google how to add widgets..
Originally posted by strmdragan View PostI am new to this . It is a android smart tv dongle . I cannot long press any icon .I feel like im missing something obvious . Internet search for solution finds nothing
you should just be able to hold your cursor over it and long press with it and change them .freaktab art developerif you like my work please buy me a pepsi
Originally posted by tattman65 View Postyou should just be able to hold your cursor over it and long press with it and change them .
Thats ok.
Originally posted by peety View PostThats ok. Everyone starts somwhere. What are you using to control it? Airmouse? Bluetooth device? an app? What? Maybe there is something fishy with the launcher that came with it. Most of them stink. Try a different launcher. Download one from playstore. Everyone has thier favorite. I use Holo launcher. Changing widget can be done by long press on screen. If its not a problem with what controller your using? Then try the different launcher..Good luck
There are currently 1762 users online. 0 members and 1762 guests.
