Rather is the update present for RK3188 chipsets in general?
Android 4.4(Kitkat) for Pipo Max-M8 Pro Tablets,availability
Originally posted by cshock2010 View Post
But since my Tablet is a wifi version only(Pipo Max-M8 Pro) ,I am unable to use this link :
Waiting for @rrileypm our saviour Friend.
Non-compatability of ROM with Pipo Max-M8 Pro Tablet
Originally posted by PolarBear View Postis supposedly here: https://disk.yandex.com/public/?hash...IJ6kcO8D0T4%3D
Mine is only a wifi version.
The only difference between the wifi and 3g versions are some drivers to make the 3g modem work....otherwise they are compatible.
If you have a 3G tablet, but don't use the 3G feature...you can flash the wifi ROM...the modem just won't work.
If you own a wifi only version...you can flash the 3G version. Since there is no 3G hardware, you should have no problems...other than a slight increase in battery consumption because of some extra processes that go on in the background. Deep sleep will likely not work.
Lately, Pipo has been only issuing one version of their firmware for both.
I looked at the Russian ROM...and I think I will pass on it for the moment. I will just wait for an official Pipo release for my ROM.
KitKat is pretty sweet on my U8 tablet, but my most recent RileyROM 4.2.2 version is the most stable ROM for the M8 Pro at the moment.Randy
There are currently 1506 users online. 0 members and 1506 guests.
