Android 4.4.beta firmware for tronsmart mk908ii,cx-919 etc
Looking for developers
http://freaktab.com/forum/advertiser...91j-smartphoneTags: None
Originally posted by geekbuying View PostBeen waiting for this all we need now is Bob to make us a nice new rom from this for my cx919
Originally posted by neomode View PostI have tested the Firmware. It is not bad, overall.
It is Android 4.4.2.
But the Kernel is not o.k. It is Downclocked to 1.2 GHz and 400 MHz GPU.
I begin to make a Custom Rom with it.
Now we get a Antutu Score of only 13.000 :-(
Neomode
Hope that will work fast with our CX-919 and AP6210.
Ansious waiting to start testing your ROM with this New Android KitKat..
Thanks for all your Efforts!!
Neomode
- sound level
- camera logitech c170
- micro sd not mounted essential to have sound and camera with google now…
Hi all,
I tried this rom out and found the following things.
Wifi works but is funky. sometimes in the wifi screen it says disabled but continues to work just fine.
Hulu, Netflix, and XBMC seem to operate well no video stutter.
SD card needs to be mounted after every boot annoying but workable.
I have no BT device so I can not check.
I have ran in to and app or to that will not run and says please disable secondary display. same apps ran with Finless roms.
As Neomode mentioned Antutu is terrible in the 13,000- 14,000 range.
this was because the rom has locked the maximum CPU to 1.2 GHz
I was able to use imgRepackerRK to unpack the ROM and then use overclockomatic script by PJ Anderson to get the speed back to 1.6GHz Doing this method I had to comment part of the script that handles GPU overclock as the Kernel had less entries that the Perl script. only down fall to this is CPU range is 1.2GHZ to 1.6 with the patched kernel
After all was said and done the kernel I repacked was 1.6Ghz CPU stock GPU and 667 Ram.
This rom remained stable and brought Antutu up to 17791.
Of course I take no credit because these methods had already been outlined here in the forum.
If anyone needs a test subject I will gladly volunteer and provide any feedback / logs needed.
Thanks to all
I was able to modify the patcher script and get
5 CPU scale steps
5 GPU steps
2 DDR steps.
Stay tuned I will have a ROM very soon with a nice selection of OC'ed kernels.
Re: Android 4.4.beta firmware for tronsmart mk908ii,cx-919 etc
Originally posted by Finless View PostI was able to modify the patcher script and get
5 CPU scale steps
5 GPU steps
2 DDR steps.
Cheers
Sent from my GT-I9500 using TapatalkFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
I frigged the MK908 beta KitKat ROM to allow its use on a T428 (equivalent) and got a decent Antutu score
Steps were:
1. Download Kasty's rooted version of the MK908 KK beta -> here
2. extracted the kernel and used patchomatic to clock cpu/GPU/RAM to 1608/600/667
3. Flashed the image, then flashed the modded kernel
4. Installed the teminal emulator apk
5. Made /System writable: su + "mount -o rw,remount -t yaffs2 /dev/block/mtd/by-name/system /system"
6. renamed the current chipset firmwares: mv fw_RK901.bin fw_RK901.bak & mv nvram_AP6210.txt nvram_AP6210.bak
7. Copied the AP6330 equivalents fw_RK903_ag.bin / nvram_AP6330.txt to replace
8. Rebooted
This made the wifi work but only on 2.4 GHz! No BTStill better than nothing and good enough for me.
I installed Antutu and it gave a result of 18,250 but with a really low GPU score which makes me think that the overclocking of the GPU didn't work.
I tested a 1080p AC3 video and it played fine using the "Video" appLast edited by d33; 02 January 2014, 12:43.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Finless KitKat ROM
OK folks I posted my new ROM based on this KitKat release.
http://www.freaktab.com/showthread.p...733#post127733
There are currently 3836 users online. 1 members and 3835 guests.
