Thanks in advance.
T428 4.4 Maybe or Anything New
**Christmas Gift** Tronsmart Release the Beta Android 4.4 Firmware For their tv boxes - Geek GadgetsHey Guys: Today is 25th Dec. First want to say MERRY CHRISTMAS to all you guys! Thanks for your support in the last 2013! Today, we just get a new […]
I tried it on my T428. Boots ok, plays files from the microSD very well, feels light and fluid. BT and WiFi are not working.
Originally posted by geonahta View Posthttp://blog.geekbuying.com/index.php.../#.Ur7AyOItmls
I tried it on my T428. Boots ok, plays files from the microSD very well, feels light and fluid. BT and WiFi are not working.T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Originally posted by Sarco View PostT428 use ap6330 for Bt and wifi, this one is for ap6210, we have to wait... but it could never be out since there is no more support for T428.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by darrellr View PostAs above, the firmwares released in the Minix 7 sub-forum are compatible. Look there for new stuff.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by flhthemi View PostI was going to flash it on mine but no wifi no bluetooth kills that plan for me.
Steps are:
1. Download Kasty's rooted version of the MK908 KK beta -> here
2. extract the kernel and used patchomatic to clock cpu/GPU/RAM to 1608/600/667 (attached -> kernel_kk.zip)
3. Flashed the image, then flashed the modded kernel
4. Installed the teminal emulator apk (attached -> Terminal Emulator_1.0.54.apk)
5. Made /System writable: su + "mount -o rw,remount -t yaffs2 /dev/block/mtd/by-name/system /system"
6. renamed the current chipset firmwares: mv fw_RK901.bin fw_RK901.bak & mv nvram_AP6210.txt nvram_AP6210.bak
7. Copied the AP6330 equivalents fw_RK903_ag.bin / nvram_AP6330.txt to replace
8. Rebooted
This will make the wifi work but only on 2.4 GHz so far. Antutu for me was 18250Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Now I can build the KK kernel I'll try to create a ROM for T428 tonight
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by darrellr View PostNow I can build the KK kernel I'll try to create a ROM for T428 tonight
Using my ipad so apols for any stupid ios spelling 'corrections'MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Can't get this to build right and it's time for bed - sorry. Will try over weekendMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 3177 users online. 2 members and 3175 guests.
