Stuck in recovery
    Stuck in recovery
    So I have this MK808, http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    I used the generic MK808 CWM zip to flash recovery and now the device only boots to recovery.
    I did not install the drivers as I don't have a windows machine, so using the MASK ROM mode I don't think will work unless there is tool for linux.
    When checking with adb, I get: List of devices attached ???????????? no permissions
    Any ideas? I couldn't get it to boot to the bootloader either, while holding down the button and plugging USB in OTG or Power port. When I do hold the button down and plug in USB to OTG port, it just stays on a black screen.
    rkflashkit is an open source toolkit for flashing Linux kernel images to rockchip rk3066/rk3188/rk3288 etc. based devices. It's programmed with python and gtk2. - linuxerwang/rkflashkit
    Yes..
    There is a linux tool 'rkflashkit' see link above
    Goodluck
      Flash this CWM rom after replacing the kernel with a MK808 one.
      Erase cache, dalvik & factory reset then install from external SDCard and select the rom from your MicroSD card or usb flash drive.
        I meant to bring this with me into the office today but forgot. I will give that a shot when I get home.
