help with rk3188 backup rom
    hello, am new here. I bought a rk3188 tablet called latte ice tab2 LV70Q a couple week ago. I install the wrong custom rom for it by accident but lucky enough, I made a backup rom of it with Rom Manager. the problem is that its not in a form of .img file so I could flash it with rktool via recovery. the files are, kernel, boot, recovery, data.ext4.tar, system.ext4.tar.the total size is over 800 mb. the problem is that I cant flash it if its not in a form of .img. Are there a tools that could combine those file into one .IMG so I could flash it? the tablet does boot up but it just show a blue blank screen.......any help or suggestion would greatly appreciated, thanks
    Rom flash tool
    You have all the files you need to flash. All you need otherwise is the rc rom tool that comes with most ROMs. Just download a finless ROM if you can't find it. Better yet, head over to ROM hacks and mods section and read a bit. Your lucky you have a back up. Good luck.
