MK808 Ethernet connection
    I have one MK808 with usb to rj45 lan adapter.
    Everything works fine but every time i disconnected the the MK808 and then power it on again it doesn't connect to the internet trow the usb to rj45.
    I have to go at definitions mark it off and then on for the device gain an valid ip, and then everything is fine until i power it of again.
    There is anyway to make the device gain a ip automatically?
    Any idea ?????
    1) Install app from Google Play - SManager
    2) Create a new file with the extension "sh"
    3) Edit the file as follows:
    ifconfig eth0 down
    ifconfig eth0 up
    4) Run SManger, and configure it to run at system startup the script that you created instep 3. Make sure that the script is run with root permissions, and most likely that you have installed Busybox.
    All credit for the write up goes to mo123
    Any idea ?????
      Ok. I will try that.
      No success
