Turn on tv, automatically start TV box.
    I bought many models (G4, MK808b, MK809II, MK908II, E888 ) and at this time only my MK809II in this list automaticaly turn on automaticaly the tv box when i turn on the tv, all other devices does not automatically restart.this is caused by the hardware or the firmware? Special patch or update is required for my other devices?
    Bonjour! Je suis de Shawinigan, Québec, Canada
    If you use the usb port of the tv as a power source, you can turn it on, of course. But, this power supply is hardly enough. I don't know, somebody knows, how to build a good power supply, which can be turned on via an external input. For example, the usb is powered on, when the tv is turbed on, it might be used. As a relay switch in other electronics, if you understand, what I mean.
    Sent from my U30GT 2 using Tapatalk 4
      Yes it is a good idea, but I want to know what There are different in MK809II allowing it to start alone with the tv. if it is just firmware or hardware?
        easylink?
        When I turn my PS3 on the television also comes on. When I turn off the tv, the PS3 will turn off as long as it is in the home menu. I believe the function is called easylink on my Philips tv, however there is a function in the PS3 menu that has the same capability, not sure the name.
        Currently Inactive on Freaktab.com
        I use: MK903V | MELE F10 Deluxe | Roku 3600R
        RIP: MK808b | MK809III | PIPO M9 Pro
