Backup NAND Flash of your rk3188 device
    I have this rk3188 tv box:
    The PCB board seem like the Doobol U2.
    I want to change the OS from Android 4.2.2 to Ubuntu or other linux...
    But, before, I want to backup the NAND flash so I can to resotre the Android OS via RockChip Batch Tool (if I will want...).
    How can I backup the NAND flash before I install another linux OS?
    Thanks!
    Any help?
      Originally posted by [email protected] View Post
      Any help?
      Of course you can backup your current ROM using a tool like Online Nandroid Backup. But more importantly : will you be able to restore the backup, because for that you need a custom recovery. CWM for example seems to work on some devices, but most Rockchip devices are flashed using the RK batch tool. And I don't know if you can restore a nandroid backup using the batch tool. Maybe a more experienced user can shed some light on this.
      Freakbox V1 F/W 1.0.6
      Asus Zenfone 2 ZE551ML Stock (rooted)
      Samsung Galaxy Tab 3 7.0 Nolekat 2.2 custom ROM
      Asus TF300T Cyanogenmod 11 Snapshot M12
      Archos 35 Home Connect Stock 2.3.4
        Thank for your response!
        In the RK batch tool can't to backup? only to flash the NAND?
          No, the batch tool doesn't do backups. That's why I would love to have a custom recovery like CWM or TWRP.
