I tried to using the ROM Manager.APK in order to backup the Android OS (from the NAND flash) before I will install ubuntu on this rk3188 tvbox (mk812A / MK813A):
But, When I click on "Backup Current ROM" (and after I enter the name of the backup---> OK...) the device restarted.
Why?
What I should to do for backup the ROM?
Go to the rom hacks and mod section of the forums. There you will find software to backup your rom. You can also google cwm for your device. If there is not one? You could use the generic rk3188...But it has limitations. You should be ok now if you do some research. Good luck!
