Which Quad Core Android stick has the best dev support?
    First I'd like to wish you all happy new year!
    I'm having a hard time deciding which android stick to get. I know there isn't a stick that stands out above the others. Funds wont stretch to a Minix X7. I think I've narrowed down my choice to either CX-919 or MK908ii.
    I've read this thread from a member asking which of these two sticks is best. But I was just wondering if a particular stick (or another stick) is better supported by the devs or more stable for xmbc etc. Reliability is important too.
    Thanks.
    You should ask Which android box is more stable with the stock rom.
    A good android box dont need 9999999 fix updates
      True, I've done a lot of reading though and there doesn't seem to be any box that is completely stable with the stock rom.
      Sent from my Desire S using Tapatalk
        Sure, the CozySwan S400 runs great with the Stock ROM.
        The Question is, what you want to do with your Stick / Box ?
        ... TVDroid
        > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
          Thanks,
          I had a look at the CozySwan S400 but it doesn't seem to have a large amount of custom rom support.
          My main uses are for watching Netflix & Youtube in HD.
            NEOMode ROMS for AP6210 running great.
            ... TVDroid
              yes
              I can agree with that. It even plays 1080p, not perfect yet, but it can do it with MX player. All 720p videos playing flawlessly.
                Thanks guys,
                I think both the CX-919 and MK908ii use the AP6210 chipset don't they. The only thing that holds me back on those are the reports of slow wifi speeds.
                  I think MTK is enough!but I have not try it~~
                  Edited by moderator: no spam please!
