CM11 for A/S8 (in-progress)
Originally posted by AManofFewWords View PostKernel recompile with it enabled.
I've actually compiled a TWRP 2.6.3.0 that can flash KitKat. But it needs a new kernel for it to work, in more detail, one with SELinux enabled. I encounter errors with compiling a kernel with CM, but works fine alone. I think it's the toolchain.
you could compile the kernel seperate.. however, make sure your environment is configured properly.. the $PATH and such.. Also, make sure you enable the required options for android in your defconfig.. Always merge the base and recommended configs for android over top of the hardware defconfig for your device..
Good luck..
Originally posted by AManofFewWords View PostWell I installed it using PhoenixSuit, which I'm afraid is likely the reason. I've searched on Google anywhere, this doesn't seem like a very spread-out problem.
TWRP 2.6.3.0 doesn't work for KitKat sadly, we need a CWM 6.0.4.3+.
Addition: I'm also using stock kernel, which could be a reason.
remember that phoenix suite wipes *ALL* partitions and re-creates them when you flash with it.
Are installing through update or through the install portion? When testing out the first zip you sent I did that and after going through install it went ok of course it didn't boot but that's what trial and error are for. I'm also wondering why we can't boot directly to recovery without first booting into the os.
Sent from my SPH-L710 using Tapatalk
Originally posted by AManofFewWords View PostMy bad I had school. I thought there was a button combination like POWER+VOL UP+VOL DOWN or something like that.
Originally posted by elektrik View Postthere *is* a key combo like that, but that only puts it into flash mode for phoenixsuit, which isn't what he's talking about. he's talking about inside recovery (at least I think). btw, for those of you who want an app to boot into recovery, check out petrus' app. He modified it for me to work with my elektricity ROM (and therefore, all allwinner based tablets). you can download from here:http://www.freaktab.com/showthread.php?1050-Reboot-App
The firmware has a built in configuration for a recovery key, however, our devices do not have a *dedicated* button assigned for this purpose. Under the current configuration, it utilizes keys on a keypad. Since we have no keypad - it is of no use.. Mapping this function to the volume-up button is something that I would love to do.. It is on my todo list.. that is... if it is possible to do so..
Originally posted by guessyet View PostThe firmware has a built in configuration for a recovery key, however, our devices do not have a *dedicated* button assigned for this purpose. Under the current configuration, it utilizes keys on a keypad. Since we have no keypad - it is of no use.. Mapping this function to the volume-up button is something that I would love to do.. It is on my todo list.. that is... if it is possible to do so..
BTW, I'm making progress in building/compiling my kernel Guess, but could still use your help-feel free to hop on tomorrow if you can help... :-)
There are currently 2678 users online. 0 members and 2678 guests.
