RK3066 and RK3188 video rewind/ time skip/ jump to time problem
Hello, I have had this problem with every rockchip stick I ever had in my hands (3x RK3188, 2x RK3066). The problem is that I can't skip a part of video in some apps that are used to play internet video content. If I do so, the audio works good but the video is playing fast forward from the previous position like it was trying to run into the new position but once it hits the position it starts to run from the beginning again. It happens with xbmc and some local TV archive apps. This is very annoying as I can't skip parts of the news or jump onto specified time in movie. Don't you know if updating the libstagefreight.so will help?Tags: None
Originally posted by driveX View PostHello, I have had this problem with every rockchip stick I ever had in my hands (3x RK3188, 2x RK3066). The problem is that I can't skip a part of video in some apps that are used to play internet video content. If I do so, the audio works good but the video is playing fast forward from the previous position like it was trying to run into the new position but once it hits the position it starts to run from the beginning again. It happens with xbmc and some local TV archive apps. This is very annoying as I can't skip parts of the news or jump onto specified time in movie. Don't you know if updating the libstagefreight.so will help?
try to flash a kikat firmware on your box and let's see if you have the same problem...
on k-r42 rewind/forward only works correctly on kitkat.
Franckfor windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
There are currently 1962 users online. 0 members and 1962 guests.
