I bought an MK809II stick from aliexpress and because the wifi signal was pretty bad and the android was a bit slowly i decided to put a new rom on it. After instaled Finless 1.7a rom the wifi and bluetooth not worked anymore. After that tryed different roms but the wifi doesnt worked with any of them. I'm started to think that its not the genuine MK809II, i attached some pictures with it, maybe you can help me with an working rom/kernel for it.
Thanks in advance !
