my brand new pipo m7 pro suffered, after a few weeks, of random and very annoying disconnections.
I have many connected wifi device at home but the pipo m7p was the only one which was unstable connecting to my router.
Symptom = connections still ok but no response to requests and after a while, disconnection !
First thing I've tried : change my router (it was using WPA2 encryption);
I decided to use the wifi function of my ADSL box (freebox HD, I live in France) instead; encryption = WPA (too bad as not wpa2 ability for that shit).
Results : nothing changed, I decided to keep that WLAN config anyway.
Next try :
alternative ROMS; I opted for Riley's 2.1.1
Results : nothing changed.
Then I've tried RR 2.3 then 2.4 but I ended reverting to kernel 2.1.1 associated to ROM 2.4 because this was for me the more stable combination.
Then I tried a couple of automatic reconnections apk : wifi tx power 0.7b, and wifi fixer 1.0.1
Results : not better.
I was desperate and a friend suggested to try a hardware fix of the antenna.
I did not find any teardown photos nor videos for this tablet and was not very comfortable to open it, but I did it anyway after I've retrieved a couple of appropriate opening tools (used in the past for replacing an iPod battery) that I think are better than credit cards for that job.
So here is the photo of the opened beast to begin with
ths small black piece on the left is the combo buttons (power and esc) that has fallen down once the back was dismounted.
