MK908 with Moga Pro Power
    Hello, I am new to this forum.
    I want to pair this Bluetooth controller with the mk908. By trying it, WiFi get lost and didn't pair the controller finally. The mk908 runs the Finless ROM 1.7a. Any suggestions to reach my goal? Somebody here owns also the Moga Pro Power?
    Gesendet von meinem Nexus 5 mit Tapatalk
    AW: MK908 with Moga Pro Power
    You suffer from a general problem with bt and wifi, for me latest finless rom made it somewhat better, while wifi bandwidth drops to a low level, it is still connected and i can stream youtube videos for example.
    _________________________
    tapatalked from GalaxyS3
      Is it possible to use a different WiFi Channel which could prevent this behaviour? I am on Channel 11.
        that depends on your area. install Wifi Analyzer from google play, that will show all the wifi in your area, then just pick a channel with the least on or around it.
          I think this wont make a difference as bt is what interferes with wifi. Try to avoid using bluetooth...
