how can I obtain which wifi chip i have old/new?
    I see all kind of roms for new wifi chip and old wifi chip
    how should I know which one i have to install ?
    thanks
    Ariel
    thanks
    Ariel
    Hi you need to take your unit apart and the wifi chip number will be printed on top of the wifi chip..
      thanks
      there isn't an app to discover this?
        And there isn't an app to open your case either!!! You might as well get familiarized with doing this task because sooner or later you will brick you stick and the only way to bring it back is to short pins on the nand chip.
        No!!! there's no app to short pins either
          AW: how can I obtain which wifi chip i have old/new?
          Lol...
          _________________________
          tapatalked from GalaxyS3
            Where is the like button?????
            Freaktab Rom Developer
              you are joking right?
              there is no app to open the case and short the nand chip?!!!
              LOL ...
              I tought that there is an app like Sisof sandra for pc that shows hardware info
                LOL ...
                No, closest you can come is to find out chip vendor by checking the mac-address against a database. However, this is not enough most likely as i guess most wifi chips are from the same vendor.
                Edit: try fing network tool for that...
                  MAC for the AP2610
                  My CX-919 has the AP-2610 WiFi Chip. The first three octets of the MAC address are unique to each vendor. As pointed out above, the same chip vendor may supply chips to many different manufacturers. Some manufacturers such as Dell, HP, Apple etc. may order chips with their own addresses. Some don't bother.
                  That said, the MAC address of my AP-2610 starts with 98:3B:16.
                  That code belongs to AMPAK Technology Inc.
                  I agree with previous posts recommending to open the case and look. I found that to be very easy. My case was just snapped together...no glue.
                  Good Luck...Brad
                    In the time it you to read this whole thread you could've; popped the case open, take a picture, posted on facebook, count the resistors, show it to all your friends and snap it back....... that simple..
                      thanks all
                      thanks all
                      its AP620
                        Good going, glad to see you were able to make progress....
                          next step fon the best rom
                          went through finless 1.5/1.6 /2
                          neomode 1.7
                          stock 4.2.2 ,4.4.2
                          still haven't deicided
