Pipo M6 3G no wifi
    Pipo M6 3G no wifi
    My m6 is 3g model, two days ago is off, use a pin to reset it and since then the tablet can not find wifi networks, it always stays activating wifi.
    I tried to put some roms, riley 1.5, 1.6, 1.7, 1.8, 1.8a, 1.9, 2.0, kasty-pipo-m6-422-20131227-rooted4, kasty-pipo-m6-422-20130814-rooted4, M6_3G&WiFi_update_20131227, M6 OTA 1.0.7_update 2013-10-15, but with all things being equal, I active wifi and seeking wifi networks.
    How I can fix it?
    Greetings
    I've tried Riley 1.9 and turn on bluetooh, and the tablet see the phone and the phone see the tablet, turn on wifi, and searching for wifi networks.
      Sounds like you have tried everything in the books to get it working.
      With the tablet on, hold the power button about 10 seconds to do a hard power off.
      Then boot again and see if wifi works again.
      If that doesn't work, you may have a hardware problem with the wifi modem.
      Some people have discovered a shorted antenna wire soldering job inside the tablet, which requires you to open the back and perform surgery. Just check the other M6 Pro threads 1.6 has some pictures of the inside and the antenna wires.
      Randy
        I do hard reset but the problem continues.
        I open the back but i don't see wifi antena, i see m9 video youtube but i don't find wifi antena in m6
          The M6 and M7 internal parts are very similar, except for size...you may be able to pick up what I'm talking about in this thread:
          There are some good pictures.
          Randy
            there is a thread when I show where are the antennas of m6pro:
              I think the problem is the wifi antenna, I don't think it's very expensive where I could buy a wifi antenna for pipo?
                Try clearing the cache in CWM.
                  or you can build it by yourself...with better results!
