What kk rom can I test in T428
    Hi all,
    I'm sorry if this is already answered elsewhere but Wichita rom on kk version can I test on my T428.
    i already have a USB/Ethernet adapter so wifi off is no issue.
    i saw kk rom for mk908 and also for others Ap6210 and also something for minix X7 if not wrong. I know I can use the x7 roms but I need some clarify on this if possible
    best regards
    I help with 4GD663269M466950W
    And you ????
    My devices:
    Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
    Tronsmart Prometheus won on CNX just now....
    please not even one answer ???
    And you ????
    My devices:
      See the Strauzo T428 kernel in experimental FW topic
      You van combine this with KK mentioned there, or the Finless KK 2.0 from here
        To elinx
        Hi i follow your post and guess what.
        Using only finless setup i have T428 booting and using the usb-ethernet with no issue.
        If burn the system.img from finless and use the strauzo kernel+boot the stick doesn't loop stays on boot screen and don't boot.
        now only going to try using the default kernelr+boot+system from strauzo to see.
        And you ????
        My devices:
