Thanks in advance
701i Battery
Originally posted by ubieubie View PostCan some one give me an idea on what the battery life is on their tablet? Also if I go to settings It says Battery usage not avalable above the chart. Is that normal or should it be saying something there.
Thanks in advanceJim
Ainol Novo 7 Elf II Dual Core
Milestone (Droid) - Chevy SS GB ROM
Milestone X - Rooted Stock GB ROM
in settings tap on battery then on the right I see
"battery usage data not available"
"99% -- charging (USB)"
"10h 10m 47s on battery" ~with a bar graph background~
when I tap on the 10h 10m part it opens up a detail graph of batt usage over that time frame..
its not much but I hope that helps
Same thing as last poster stated. I am having a problem with my tablets battery life tho. It beeped and said battery low and time to charge it. Yet when I checked to see how much time was left on it, it said 3 hrs and something. I used it till it went out and am now charging it.
I am wondering why it would say there are 3 hrs and something left on it, when the battery was low and needing a charge?Tablets: Polaroid PMID 701i, PMID 4311, Zeki 10" tablet
"God Loves You"- Arlo Guthrie
Originally posted by cherylharrell1961 View PostSame thing as last poster stated. I am having a problem with my tablets battery life tho. It beeped and said battery low and time to charge it. Yet when I checked to see how much time was left on it, it said 3 hrs and something. I used it till it went out and am now charging it.
This is true no matter what device you 're using. I often get the same thing when I hook up a portable usb drive to my laptop while it's running on battery power and do a lot of up/downloading to the drive.
If you make a change that signifficaltly affects the battery (such as flash a new ROM) it is best to us an app too help calibrate the battery. I use Battery CalibrationbyNéMa.
Once the battery fully charges you press the "Battery Calibration" button. Then you are supposed too let the battery run down until the device shuts off. Then put it on charge and let it charge without interruption to 100%.
I'm calibrating my tablet battery right now. It's been 15 hours since I unplugged and I still have 61% to go. I'm going to have to do something to consume more battery if I want to put it on charge before bed time.
Normally you don't want too run your battery down all the way. Lithium batteries can be topped off whenever it convenient. No need to worry about 'memory effect' like ni-cad batteries had.
Oh, and I use Auto Airplane Mode by DON to put the tablet in airplane mode when the display timeout occurs. This extends the battery life and keeps the wifi from hanging when the tablet comes out of sleep.
Jim
I just found out I had been reading the battery display wrong due to looking at it in low light. The 3 hrs was how many had been used since the last charge. It doesn't seem to show how many hrs or time is left on it which is a shame. Oh well.Tablets: Polaroid PMID 701i, PMID 4311, Zeki 10" tablet
There are currently 1836 users online. 2 members and 1834 guests.
