I bought TV01 unit in geekbuying, its supposed to be a clone by the same factory that makes cr11s and cs968. The problem is everytime I tried a rom with 1080p and I had picture problems, like black lines appearing and dissapearing, when i chose 1080p mode. Has anyone any idea? Hardware problem? I wrote to geekbuying and they said its a problem of unstability with the 1080p and that they will contact the manufacturer for newer roms, but I didnt see anyone complaining about cr11s or cs968 1080p mode. Ive been thinking that maybe lowering the frequency of the gpu could help to stop this problems. Thanks.
TV01 m1080p issues.
TV01 m1080p issues.
Hello,
I bought TV01 unit in geekbuying, its supposed to be a clone by the same factory that makes cr11s and cs968. The problem is everytime I tried a rom with 1080p and I had picture problems, like black lines appearing and dissapearing, when i chose 1080p mode. Has anyone any idea? Hardware problem? I wrote to geekbuying and they said its a problem of unstability with the 1080p and that they will contact the manufacturer for newer roms, but I didnt see anyone complaining about cr11s or cs968 1080p mode. Ive been thinking that maybe lowering the frequency of the gpu could help to stop this problems. Thanks.Tags: None
You can get the Newly Released CR11S/CS968 PRE-ROOTED (NOW VPNOPEN READY) 1080p 2MP Stock ROM Libmedia.so hack ready 20131205 HEREhttp://www.sendspace.com/file/yj080y .... Here is the link to the app, "VPN One Click" https://play.google.com/store/apps/d...ck.VPNOneClick (No Side Loading Required).... Get the Fancy Widget Clock HERE http://www.mediafire.com/download/cn...dgets3.5.5.apk (Side Loading Required)... If you want more of the most popular XBMC add-ons, plugins, (FREE CABLE, *MASH UP,YIFY MOVIES, SPORTS DEVIL, ICE FILMS. 1CHANNEL, TUBEPLUS, USTVNOW, TGUN and MORE ), repositories zip files, then go HERE https://plus.google.com/communities/...20500984874818 ... The add-ons, plugins, and repositories zip files link will be located at the bottom of the right hand column in the blue links section TITLE (XBMC Plugins/Repositories Zip Files), click on this link ...! (*Mash UP:Rated The #1 Plugin Zip File For XBMC), (This ROM Build Is Confirmed By The Cloudnetgo Website)
There are currently 3330 users online. 0 members and 3330 guests.
