[Q] Next Book 7P12-8G Andriod version 4.04 Rom
I was handed a Walmart $69 NextBook 7P12-8G Serial # YFG091311XXXX. I did a little research got enough to root it and then THOUGHT I had the right rom for it. I flashed what I thought was right, so now I have a mostly working tablet minus wifi. I know stupid me for not reading everything I could on everything. So my question is because I can not find it via searching google, XDA, etc.. How can I tell what chip set I have? and if there is a rom I could flash it with to get the wifi back at least.
ThanksTags: None
Originally posted by not1ofthepack View PostI was handed a Walmart $69 NextBook 7P12-8G Serial # YFG091311XXXX. I did a little research got enough to root it and then THOUGHT I had the right rom for it. I flashed what I thought was right, so now I have a mostly working tablet minus wifi. I know stupid me for not reading everything I could on everything. So my question is because I can not find it via searching google, XDA, etc.. How can I tell what chip set I have? and if there is a rom I could flash it with to get the wifi back at least.
ShaunMTFreaktab Rom Developer
Regarding Next7P12-8G WIFI Issues
The only complete ROM I currently have for the Next7P12-8G is dated 10-23-13. This is the build the stock ROM I have already released is based on.
For you guys that are having WIFI problems. You need to provide the serial number from the sticker on the back of your tablet or from the box so we can determine when it was manufactured. Then we'll need to find someone with an original ROM that can provide a ROM dump.
Originally posted by shaunmt View PostThe only complete ROM I currently have for the Next7P12-8G is dated 10-23-13. This is the build the stock ROM I have already released is based on.
ShaunMT
Currently mine will only allow me to access the system recovery, with the lady listening to the music staying there forever on the second screen with the Nextbook logo. Let me know if there's anything I can do to help, or additionally, if your update will fix it.
Cheers!
Originally posted by maxdelfuvio View PostHey. I had my Nextbook screw up during boot, and I'm considering flashing, but all of these serial numbers make it a pain to guess. You mention a ROM dump, and I haven't yet flashed mine, but it may not be what you're looking for. The serial is YFG0313XXXXXX.
Cheers!
We identified that Nextbook used two different WiFi chips in the Next7P12-8G. It won't be possible to determine which WiFi chip is in yours if you can't currently boot. My ROM will boot but WiFi may or may not work.
I'm currently finishing up testing on new modified ROMs for both WiFi chips, so if WiFi doesn't work using the current stock ROM, you won't have to wait long for a fix.
Yeah I'm sorry for the necro. I can't find anything for my tablet and Google is giving me the runaround, so I ended up here.
Can you point me in the right direction for where I need to be looking or waiting for something to help? I hate to use this thing as target practice unless it absolutely won't work. It's weird the bootloader arguments suddenly go null, but it is what it is. Thanks!
Originally posted by maxdelfuvio View PostYeah I'm sorry for the necro. I can't find anything for my tablet and Google is giving me the runaround, so I ended up here.
http://www.freaktab.com/showthread.php?12619-TWRP-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Support-Thread)&p=174963#post174963
Watch here for the new ROMs to be posted:
http://www.freaktab.com/showthread.php?11652-ShaunMT-s-Modified-Stock-Based-ROMs-for-Amlogic-Nextbooks-(Support-Thread)
You could also subscribe to my dev bio page (linked in my signature below) for updates on everything I release.Freaktab Rom Developer
New Next7P12-8G Modified Stock Based ROMs Available (Both WiFi Versions)
New Next7P12-8G Modified Stock Based ROMs Available (Both WiFi Versions):
http://www.freaktab.com/showthread.php?11651-ShaunMT-s-Modified-Stock-Based-ROMs-for-Amlogic-Nextbooks-(Download-Thread)
ShaunMT
Will these work for the Ematic Genesis 2 Tablet, which says in the back of the tablet is also called the NextBook7P12-8G? Didn't come with a SN sticker with the YF serials, but a custom sticker that starts with EMGS. Sadly, the Ematic site does not have the Genesis 2 listed in their support.
Originally posted by UmiKaru View PostWill these work for the Ematic Genesis 2 Tablet, which says in the back of the tablet is also called the NextBook7P12-8G? Didn't come with a SN sticker with the YF serials, but a custom sticker that starts with EMGS. Sadly, the Ematic site does not have the Genesis 2 listed in their support.
If the hardware is exactly the same, it should, but if the hardware is not exactly the same, it either won't work correctly or may not boot at all, and it will be impossible to fix without the stock firmware.
Originally posted by UmiKaru View PostAccording to this CPU Identifier app,
CPU: AMLogic AM8726-M 1Gz
Smartphone Type: Ematic ETM727MC
GPU: Mali-400 MP (single core)
RAM: 1Gb DDR
Probably the same board... the Next7P12-8G have the board identified as NXM727MC... looks like the first two chars identify the vendor.
There still isn't any way I can guarantee everything will work though.
Try at your own risk.
Re: [Q] Next Book 7P12-8G Andriod version 4.04 Rom
Originally posted by UmiKaru View PostWhat's the first step to load your ROM? I have the tablet rooted, but it wont show the uimage_recovery in any sd card location. I have it in the root of the internal and external cards.
Then you just use the recovery as you normally would.
I assume you know how to use a recovery to flash to .zip files?
P.s. if twrp hangs or the tablet reverts to stock recovery instead then the twrp and the rom are not compatible with your device.
Sent from my SM-G900P using TapatalkFreaktab Rom Developer
There are currently 1002 users online. 2 members and 1000 guests.
