Si riavvia da solo Ug802
    Hello people. I purchased this ug802 and from the beginning I can not get it to work as I want (or should). I put it in the room about 3 meters away from the modem with a 10cm thick wall. The wifi signal reaches half and I can navigate but sometimes goes in spurts. I tried to pull out the antenna but the result is always the same. So I took a USB / LAN and connected with powerlink, directly to the modem. Works with navigation but when I stream through my dreambox will reboot by itself .
    I would try to install the finless 1.7 to see if it improves, but I can not.
    Give me some advice (in addition to throw it away )?
    The firmware version is 4.1.1.
    (sorry for the translation via Web)
    Hi Bicromia, i'm Italian :-D
    Can you send a photo of the pbc device?
    In my opionion, if you have usb hub and ethernet usb, the system reboot for low power source.
    Can you add more Ampere at your power supply?
      Hello lungomare.
      At my powerline lacks the power supply, will want to say that I have to get it for me and do this test.
      What voltage should have the power, as it was not included.
      These are some photos as you asked me:
      I hope I see good.
