Ethernet adapter for M6Pro
    Can anyone suggest which ethernet adapter will work on my M6Pro with RileyROM 1.6.1? Does the ROM matter to this or will any mini USB ethernet adapter do the job.
    The Pipo site has a list of compatible Ethernet adapters.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Randy
      Yea I thought I had seem a list there but at the moment I can't seem to find any links to it.
        I would appreciate the link as well.
        Thanks in advance.
          so no one got any idea where that list of compatible ethernet cards has gone from the Pipo site then?
            Here's some:
            Here's some:
            pipomall.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf pipomall.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
            Sent from my M7pro using Tapatalk
              Originally posted by littlepriest View Post
              Here's some:
              Here's some:
              www.pipomall.com/pipo-accessories-usb-ethernet-adapter-c-580_561_569.html
              Thanks, yes seen them. Rather than having to order and import from China I was hoping to find the list of which USB to ethernet adapter chips were supported by the M6. That way I can just order one from the UK.
              I do remember seeing that list of supported ethernet chips before but can't find it anywhere at the moment.
                what parameters I have to put the adapter to work?.
                thanks
                  I ordered one Ethernet adapters from Pipomall for my M9pro.
                  I is working fine without installing any driver (close WIFI!) But he is very slow!
                  There is a KY-RD9700 chipset inside. This RD9700 chipset is USB 1.1 not 2.0!! That's why the speed is only 6Mbit!!
                  Look for adapters with the ASIX AX88772 chipset. They are using the full USB 2.0 speed!
                    I have the adapter, but the M6 Pro not recognized automatically, I can do?.
                    thanks
                      thanks
                      Disable WIFI, enable ethernet then plug the adapter to the tablet. (plug and unplug several times if necessary - wait til the red LED starts flashing) or try with reboots.
                      My M9 pro with Finless Rom 1.5 recognized this adapter after 2 times unplug!
                      http://www.****.de/itm/171158262488?...84.m1423.l2649
                      Good luck!
                        Good luck!
                        does not work, it is possible that the adapter is damaged
                          do you connect the adapter to the OTG-Cable or directly via micro USB-plug?
                            Tablet; OTG; Adapter; Ethernet.
                              My idea was that you could have the problem because of a too short micro-USB plug (PIPO plugs must be 1,5-2,0 mm longer than usual)
                              Check the adapter function on a Windows or a Mac PC!
