[Q] Mount external hard drive as internal storage to play games on
    Hello
    I just bought a 1TB hard drive and I was wondering if it'd be possible to use that storage to install games. I already tried a mount app that mounted the android\data\that app to the external hard drive but the game didn't regocnise it (Asphalt 8).
    Any ideas?
    You probably need to edit the permission in Android Manifest file
    Aka.. give the app permission to read and write to usb external drive
    What did you do.. to move/mount the android dir?
    And do you have root?
      Originally posted by mitchell4you View Post
      Hi, thanks for your reply!
      I used this app https://play.google.com/store/apps/d...evasque.fmount
      (and i have an mk908II, dunno if that matters)
      The app just mounts a directory of the external hard drive to the SD card (mnt\sdcard\android\obb\com.thegame)
      So do you think it has to do with the permissions of the app? (btw mounted, es file Explorer displays the obb file like it was just there on the SD card while it isn't (that workes!))
      Oh and yes I'm rooted
        Never heard of this app... But it looks neat
        here is some light reading:
        http://forum.xda-developers.com/showthread.php?192122
        How to?
        Hello this is a guide to "move" you apps to your SD card for users with small Internal Storage Update:There is now a faster way to do it. After step 3 you just press the menu option on the top left corner and you press app analyzer. This will...
        Freaktab users
        Cheers
