Nextbook 8 rooted nx008hd8g (made after 8/13)
Been looking around theres been on root methos or any kind of development done for the nx008hd8g with the serial beginning with YFG1013.Im no dev i just like playing with my toys, so after a few failed root methods i came across cydia impactor downloaded and ran it n boom rooted...now heres the skinny... i may have obtained partial root via other methods im not advanced enough with my tinkering to be certain and i dont really wanna hard reset to test to see if the impactor will do all the work.SOOOOOO... any devs willing to walk me thru dumping the rom so more ppl can obtain root with this tab id be more than happy to comply and if anyone is willing to try cydia on a fresh tab tht may clear up weather or not partial root is required first hand thnx guys -
Originally posted by Xeriios View PostBeen looking around theres been on root methos or any kind of development done for the nx008hd8g with the serial beginning with YFG1013.Im no dev i just like playing with my toys, so after a few failed root methods i came across cydia impactor downloaded and ran it n boom rooted...now heres the skinny... i may have obtained partial root via other methods im not advanced enough with my tinkering to be certain and i dont really wanna hard reset to test to see if the impactor will do all the work.SOOOOOO... any devs willing to walk me thru dumping the rom so more ppl can obtain root with this tab id be more than happy to comply and if anyone is willing to try cydia on a fresh tab tht may clear up weather or not partial root is required first hand thnx guys
Cydia Impactor always works on all current Nextbook models.
I've already received a new stock ROM dump.
An updated stock ROM and Flashable root are coming soon.
CWM and Cyanogenmod are also coming soon.
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostCheck the Amlogic Nextbook subforum.Cydia Impactor always works on all current Nextbook models.I've already received a new stock ROM dump.An updated stock ROM and Flashable root are coming soon.CWM and Cyanogenmod are also coming soon.ShaunMT
Nextbook 8 + Cyanogenmod
ShaunMT
thanks
Originally posted by sapelzin View PostAny idea on timeframe for Cyanogenmod. A ROM upgrade would really make the Nextbook sing.
thanksFreaktab Rom Developer
Originally posted by no1udknow View PostI can't seem to locate a definitive answer, but has anyone locked down a solid root/roms for these tabs?been lurking for a while and decided to register. You guys are great and look forward to the things I can learn here.
Originally posted by roadkill View Postwhat board u have if u dont know down load cpu z then in stall then run and go to the system tab if u got wm tjere is some cm10 and cm11 roms out but still buggy
Root
Originally posted by no1udknow View PostWell, so far I am reading about a lot of bricks on this model so I may have to cool my jets and wait till something stable comes along. The last thing I want to do is turn my Xmas gift into a drink coaster.
Originally posted by roadkill View Postthe things here ar stable u just have to make sure u have the right roms or cwm for the rightmboard whitch is easy if u jave any questions pm shaun he make sure u have the corect files i recomed rooting only unless ur curent rom is not working right mine is rooted amdni switch beteen three diferent roms and no problems
Originally posted by roadkill View Postithe install cpu-z it tell u what board and other things in the system tab
I imagine at this point there is no Kk kernel available. Any hope for that?
I have the WMN board. What do you recommend. I mostly want to root and install a debloated ROM so I have a little more space.
Can't do anything yet to get more app space... Normally, we would remove some apps from the system partion, make the system partition smaller and increase the size of the data partition for apps, but on these devices, the partition sizes are hard coded in the kernel. We need a custom kernel to change the partition sizes.
The only other option is to change the mount point for the external SD Card to make it available for app storage. (I haven't tried this yet, so I can't provide instructions.)
There are currently 2891 users online. 0 members and 2891 guests.
