Today I figured out how to patch 3.0.36+ KitKat Kernels to 1080P!
The code for these changed for 3.0.36+ JellyBean kernels.
I have to tell you, to figure this out requires decompiling the kernels and finding the code.
Not easy and full of PAIN
Special thanks to FreakTab developers darrellr and Wasser!
They provided me kernels to decompile and compare thus finding the patch locations!
I could have done it otherwise but it's a lot more work.
So THANKS guys!!!!!
So you might ask.... Why patch stock kernels?
Well... believe it or not, SOME people want stock because they know it came from the Manufacturer
and was not "public" generated. I know that sounds silly but this is why I spend the time patching.
__________________________
So in this download are:
1) A stock Tronsmart kernel patched to 1080P. Nothing else.
Now understand why the stock Tronsmart kernel gets low Antutu scores!
It is clocked to 1200 CPU only and DDR is also under clocked compared to JellyBean kernels.
I don't know why they did that but this is why it's a BETA release from them,
2) A full set of Over Clocked kernels patched to 1080P.
Again these are stock Tronsmart kernels patched to 1080P.
Then they are OverClocked using Mr. Andersons patch-o-matic scripts.
I find for the CX-919 the kernel:
kernel_1080oc_cpu1608h_gpu600h_ddr667.img
Gives me the best trade off of heat (with no worry of frying your stick) and performance.
This is true for the 720 kernels I already provided in my ROM.
This gives me an Antutu score of 17000 for a 1080 kernel.
A 720 kernel of this same OC gives 19000.
I think it is also safe to use:
kernel_1080oc_cpu1608h_gpu600h_ddr720.img
But depending on your stick you might have stability issues. Still no fear of frying your stick though.
It's when you go above 1608 and GPU over 400 do you start to worry about heat.
Thus if you use these higher OC kernels please consider cooling and heat sinks.
Instructions:
There is NO NEED to erase NAND and reflash the entire ROM!
Just use the flash tool from my KitKat ROM kit.
One the kernel line click the far left empty box and point your file browser to the kernel you want.
Flash that ONLY e.g. uncheck everything else in the flash tool except the kernel line.
___________________________
Here is the download link for the kernels:
ROM -> 1080P KitKat Kernel Set for Finless KitKat ROM 2.0 (192 megs)
Enjoy,
