CS918 or CS918s
Wierd..
In your first post.. you state ordering a CS918S
And now you ask...
Anyway..
There are many revisions/versions of the cs918, it a gamble what you get
If you are lucky..
Then you can choose many firmwares/kernels on freaktab to test (like kitkat)
If you are unlucky..
No choose.. but the stock firmware.. and the hope.. that it runs stabile or till somebody makes a custom rom
If you are a tweaker..developer
Then rk3188 devices are a good choose.. lots of tools and source code
The CS918S is quite good.. out of the box ( the pre-installed xbmc does not work.. just remove it/replace it with SPMC)
But there are currently no custom roms.. (yet)
Time will tell if it ever gets upgrades
Both run xbmc.. quite good.. these days
(cs918 hat some problems in the past,but even the stock fw have improved quite alot )
Cheers
There are currently 2473 users online. 1 members and 2472 guests.
