Android 4.4 KitKat Beta Firmware for Tronsmart MK908 V1 and V3 version
    Some days ago, we post the Android 4.4 Kitkat Beta firmware for Tronsmart MK908 V5 version. some V3 and V1 board owners complaint about the lack support of their board.
    Today, after talk with factory, Tronsmart release the Android 4.4 Kitkat beta firmware for V1 and V3 board users. you can download the firmware here:
    http://www.mediafire.com/download/ps...8_100k4_v3.rar
    Flash tool is here:
    http://www.mediafire.com/download/cm...ool%20v1.7.rar
    Please notice, this is just BETA FIRMWARE, there should be some bugs, we hope you can help to report, and we will transfer to factory, and push them to release the official version asap.
    PS: for Tronsmart T428 users, you can try this kitkat firmware;
    http://blog.geekbuying.com/index.php/2014/01/13/rom-download-tronsmart-a928-quad-core-tv-box-android-4-4-kitkat-beta-firmware/
    it should work on Tronsmart T428.
    Enjoy!
    Hope bob will cook some for us
    Tronsmart MK908 Since 2013
    Himedia Q5 III Since 2014
      I will work on it but remember I cant test V3 so here we go again ......
        I have installed it and i will test it soon...
        www.sacvideolari.com www.babatorik.com
          hi i have a question is Wifi working ?
            So for as i test it everything working. no restarts so far.
              its not rooted, how can i root?
                I tried this link, and it worked for me
                  I am having strange problem, looks like some buttons pressed by itself. is there anyone having this issue?
                    http://www.kingoapp.com/#
                    Thanks i will try it
                      If you need a tester I have both V3 and V5 MK908's
                      Your Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA works on V5 with V5 recovery and kernal but on V3 wifi is not there. It's just sat there saying turning on. If that helps
                        Here what i see on this firmware;
                        • after a while (8-9 hours of working) colors became broken!, (or right after wake up from sleep)
                        • stable and no reboots!,
                        • sometimes (some) applications forced to close (like xbmc, google+),
                        • video play is almost perfect (MX player pro (with HW+ Decoder)) but i see sometimes some little stutters on 1080p videos,
                        • wifi not disconnects but works slow.
                        • shutdown not work (i think. blue led never turns off). If you pull out from the usb power and plug it again, it enters to the "safe mode".
                          that colour thing I can confirm and say is really weird.
                          Not had a reboot or app crash, but only use ir for abour 2 hours a time
                          not had safemode on pulling power yet.
                          Also not been able to root the device yet. but really havn't put too much effort as the V3 is my secondary device.
                            kernek & recovery for V3 to boot finless2.0 beta
                            The files are extracted from the update_mk908_100k4_v3 rom, i already verify that finless2.0 beta can use them to enable wifi connection. Speed is good enough.
                              I will try to change resolution for a quick solve the color thing, if it happens again.
                              If I try to shutdown or reboot (with a 3rd party software) it enters to the safe mode after boot.
                              (You need to press the flash button right after the connecting usb power, till main screen comes, to exit safe mode.)
                              Kingoapp successfully rooted the device, confirmed. (You need to connect both of usb's to the pc. That was only way my pc recognized the device)
