Arnova 10G2 with 8GB, Stock Firmware needed
    Hi everybody,
    i'm new here and i hope somebody can help me with my problem.
    I've bought an Arnova 10G2 Tablet with 8GB on ****. Yes it's
    a 10G2 with 8GB and not a 10bG2 with 8GB. Stock Firmware is
    Android 4.03 but this Firmware is not available on Arnova Web-
    page. Does anyone have this stock firmware? I've flashed several
    custom FW's but no one supports 8GB and the touch works also not
    accurate.
    Yes, i've dumped my pad, and i can reinstall my dump, but then the
    touch doesn't work anymore. What goes wrong? Can anybody help?
    Sorry for my bad english, hope you will understand my problem ;-)
    Chris
    Originally posted by schrisis View Post
    Hi everybody,
    accurate.
    Chris
    we would need to see a copy of your firmware dump . to the best of my knowledge the 10g2 never came out with a stock ics firmware . if you can provide a link to your dump the we may be able to figure out whats going on .
    freaktab art developer if you like my work please buy me a pepsi
      Hello tattman65,
      thanks for your reply. Yes, the initial version of the 10G2 was delivered with Android 2.3, was is mentioned on the box. But there is an additional sticker which says, that ICS is installed. I've linked some pictures of the original box here:
      Also i've packed my dumped backup.img and uploaded it here:
      http://www.4shared.com/rar/Fbsc7bcEba/backup.html
      Hope this is the right file.Chris
        Hello tattman65,
        just hold tight and we'll have a look ok .
          It may be tomorrow...but I'll download and take a look at it.
          Sent from my U8 using Tapatalk
          Randy
            I made a test ROM to try. It's rooted.
            One thing I had to do is extract the kernel out of the boot.img and sign it. Maybe that will help, but I'm not sure.
            I didn't look to see if there were more apps to debloat from this ROM...I'm headed out the door pretty quick for a basketball game.
            Download
            Randy
              Download
              hey Randy if we don't hear from this guy, i'll try it on mine when i get home tonight .
                OK. I haven't had a chance to test it.
                Sent from my SAMSUNG-SGH-I537 using Tapatalk
                Randy
                  Hey Guys,
                  thanks for your effort. I gave it a quick try, but the pad doesn't come out of the boot screen.
                  Don't know why. I have checked out the parameters and there are differences in the offsets.
                  Here are the parameters i saved:
                  FIRMWARE_VER:0.2.3
                  MACHINE_MODEL:AN10G2I
                  MACHINE_ID:007
                  MANUFACTURER:RK29SDK
                  MAGIC: 0x5041524B
                  ATAG: 0x60000800
                  MACHINE: 2929
                  CHECK_MASK: 0x80
                  KERNEL_IMG: 0x60408000
                  CMDLINE: console=ttyS1,115200n8n androidboot.console=ttyS1 init=/init initrd=0x62000000,0x800000 mtdparts=rk29xxnand:
                  0x00002000@0x00002000(misc),
                  0x00004000@0x00004000(kernel),
                  0x00008000@0x00008000(boot),
                  0x00008000@0x00010000(recovery),
                  0x00100000@0x00018000(backup),
                  0x0003a000@0x00118000(cache),
                  0x00100000@0x00152000(userdata),
                  0x00002000@0x00252000(kpanic),
                  0x00100000@0x00254000(system),
                  -@0x00354000(user)
                    Hey Guys,
                    FIRMWARE_VER:0.2.3
                    MACHINE_ID:007
                    MAGIC: 0x5041524B
                    ATAG: 0x60000800
                    MACHINE: 2929
                    CHECK_MASK: 0x80
                    -@0x00354000(user)
                    i've got a couple of 10g2's ,when i get home i'll give it a look and see whats going on.
                      OK, I let my kitchen make the parameters automatically. Let me do a manual parameter check and see what went wrong.
                      Which parameter file did you try?
                      Randy
                        OK, as I recall, there is only 4gb of NAND on the 10G2...correct?
                        If that's the case, we can only safely use a 2gb parameter setting, otherwise it won't leave room for the system, or any internal NAND storage.
                        So I edited this 2gb parameter to replace the one in the ROM kit. I just wasn't thinking about how much NAND was on it.
                        Here you go:
                        Code:
                        FIRMWARE_VER:0.2.3MACHINE_MODEL:AN10G2I
                        MACHINE_ID:007
                        MAGIC: 0x5041524B
                        ATAG: 0x60000800
                        MACHINE: 2929
                        CHECK_MASK: 0x80
                        CMDLINE: console=ttyS1,115200n8n androidboot.console=ttyS1 init=/init initrd=0x62000000,0x800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00008000@0x00010000(recovery),0x00100000@0x00018000(backup),0x0003a000@0x00118000(cache),0x00400000@0x00152000(userdata),0x00002000@0x00552000(kpanic),0x00102000@0x00554000(system),-@0x00656000(user)
                        Randy
                          i'm letting it sit right now Randy , just flashed so lets see what happens.
                            Here is a 1gb parameter file:
                            Randy
                              Randy my friend ,it's still just sitting here at the bootimage, 1gb par. did not help .
                              do you think maybe i could try an older flash tool ? like 1.29 if i recall there was some issues with different flash tools , or something . wow that was awhile back .
