No luck for mk808 or mk808b yet?
MK808B and HDMI audio passthrough
I modified my MK808 rom based on MK808 Nov 2013 Geekbuyers rom + Beelink MK808B Mar 2014 kernel. I've replaced audio driver and firmware files from /system/lib,hw and etc, and settings.apk and settings-provider.apk with those from the rikomagic mk802 Mar 2014 rom. The HDMI PASSTHROUGH sound option can be selected, but unfortunately doesn't work: in MX Player and XBMC there is the clicking noise when passthrough is selected. We need to find a rom for a similar device which has passthrough and transplant the kernel. Alternatively we must build a kernel from sourcecode which has passthrough config options. I also tried the MK802iiiS kernel, but unfortunately not booting (stuck on splash). Anybody who knows other devices similar to MK808 with roms including HDMI PASSTHROUGH ??
I will try to provide debloated roms with 1080p kernels for mk808 and mk808b next week. You can have a quick start by installing and test this rom "Rikomagic MK802IIIS8G(B) Android 4.2 Software(131107" from here:
Shenzhen Rikomagic Tech Corp.,Ltd-----Android TV BOX, Media player, Digital Signage Media Player,signage player
There is a chance that wifi does not work on your mk808b, in that case use a cheap usb-ethernet adapter. The rom should boot up and offer you both MULTI5.1 and PASSTHROUGH devices.
Please provide your test feedback in this thread.
Originally posted by jockyw2001 View PostI will try to provide debloated roms with 1080p kernels for mk808 and mk808b next week. You can have a quick start by installing and test this rom "Rikomagic MK802IIIS8G(B) Android 4.2 Software(131107" from here:
Originally posted by PMisYMMV View PostDoes wifi on mk808 (non-b) work with rom ?
See this chart: http://s1254.photobucket.com/user/tw...2a5b6.jpg.html
Perhaps it is possible to patch just the system modules configuration to provide the matching wifi drivers, but I am afraid the kernel also must match wifi chipset. Some more research needed.
It's good having the 5.1 sound working but just a shame loosing the wifi...
Good luck
Thanks!
There are currently 2917 users online. 0 members and 2917 guests.
