Bricked PiPo S1 Pro Nand 29F64G08A
    Sorry for my very bad english
    I flash a ROM from S1 to S1 Pro i didn't see it, open the tablet and try to boot in MaskRom but the nand isn't SanDisk is 29F64G08A... and don't works reset bridge the pins 8 and 9
    What I can try?
    Try 7 and 8.
    Otherwise, at this point...try other combinations. It wouldn't hurt.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Randy
      Thanks rrileypm for your response
      I try to short 7 and 8 in the left and right up and down but doesn't work
      1 - Open
      Rockchip Batch Tool v1.7 and load firmware i also try Finless ROM Flash Tool 1.37
      2 - Bridge points
      3 - Conect USB
      is it correct?
        Have the USB connected and the flash tool running. When you get the correct pins, the tool will say "mask mode".
        Randy
          YEEEEESSSSSSSS!!!!! the tablet back to the life, THANKS rrileypm for your help.
          The points i bridge is near to Nand chip, if you see previous image, the pads located in the left side of the Nand chip, sorry i don't remeber the pins probably 7 & 8 or 8 & 9 start counting down pin to up pin
          THANKS
