nextbook 7 w/android 4.0 @ biglots...$99.00???
    Whaty we want is backup.img
    For you that would be
    /data/rkdump /dev/block/mtdblock4 /sdcard/backup.img
    You do have a sdcard installed?
      Hello!
      Yes, but not at /sdcard. The INTERNAL SD card is at /sdcard, but the EXTERNAL SD card is located at /mnt/external_sd.
      I also had to send the 'adb root' command to push rkdump into the /data folder...
      73 DE N4RPS
      Rob
        So did you get it dumped?
          Hello!
          Yes. Mission accomplished (or so it would seem)!
          C:\ADB>adb devices
          List of devices attached
          NXM723HRF0123456 device
          C:\ADB>adb push rkdump /data/
          1560 KB/s (63916 bytes in 0.040s)
          C:\ADB>adb shell
          root@android:/ # cat /proc/mtd
          cat /proc/mtd
          dev: size erasesize name
          mtd0: 00400000 00004000 "misc"
          mtd1: 00800000 00004000 "kernel"
          mtd2: 01000000 00004000 "boot"
          mtd3: 01000000 00004000 "recovery"
          mtd4: 1e000000 00004000 "backup"
          mtd5: 07400000 00004000 "cache"
          mtd6: 20000000 00004000 "userdata"
          mtd7: 00400000 00004000 "kpanic"
          mtd8: 1cc00000 00004000 "system"
          mtd9: 89200000 00004000 "user"
          root@android:/ # chmod 755 /data/rkdump
          root@android:/ # /data/rkdump /dev/block/mtdblock4 /sdcard/backup.img
          update.img found (315969536 bytes)
          dumping...
          crc found (4 bytes, 0xd2bcd28f)
          done
          root@android:/ #
          Where do you want me to upload it to? I set up a Mediafire account recently; I could put it there, but will have to buy more space there. The image is 300 MB, and Mediafire has a 200 MB per file limit.
          Can I use this update.img file I dumped 'as is' to restore my tablet if I have to? I've seen that 'update.img' term bounced around by various tablet manufacturers...
          73 DE N4RPS
          Rob
            Do you know how to FTP?
            I will PM you with a FTP location here on our server.
            Cograts on the dump!
              Thanks n4rps and fin u are life savers,hope fin and you can root this thing and get play working also,congrats on the dump,i know im jumping the gun a lil how hard would it be to make aokp or a cm9 port on are beloved 7s??
              Sent from my HTC Glacier using Tapatalk
                Swap or not to Swap?
                Polaroid 701i vs. Nextbook 7 Android 4.0 Ice Cream w/ camera , WiFi
                What does factory rooted mean...benefit of rooted vs. nonrooted...accepts ADB commands...and ROM dump/ replacement benefits? Should i keep polaroid or go in get the Next book. My goal is simply to video chat. Will camera on front of Next 7 allow video chat? Can you add a cmaera to the Polaroid via USB...Will it enable a Skype video chat? Thanks
                  aokp or cm9 port? Please school me?
                  What would an aokp or cm9 port enable me to do additionally on a Next Tablet 7 if I get one? Is a Next brand better than a Polaroid brand in quality/durability/functionality construction? Thanks
                    Hello!
                    I imagine I'll be asked to put rubber to the road before I know it, and offer up this thing as a sacrificial lamb.
                    If the features you refer to are available for other Rockchip ICS tablets, I wouldn't think it'd be that hard to incorporate. However, that's a question best answered by Finless, as HE'S the one doing the 'grunt work' here...
                    73 DE N4RPS
                    Rob
                      Hello!
                      As Finless has said, the final decision about whether to exchange tablets or not is up to you. A FULL comparison between the two might best be covered in a thread of its own.
                      Rooting a tablet is a requirement for some apps to work as they were intended to. That's why it's important, but not ALL-IMPORTANT - at least not to ME.
                      Nonetheless, it'd still be nice to have a rooted tablet right now. BTW, 'rooting' a device usually voids the warranty on it.
                      As for ADB, that stands for Android Device Bridge. Developers, ROM chefs, and hackers use it to communicate with the tablet directly. You usually need this inteface to work to install a custom ROM, and I needed ADB to be talking to my NextBook to provide a ROM dump for Finless to modify for us. That's what took me so long to get the ROM dump to him. Modifications to some Windows config files must be made to pull it off, and it took me time to figure out what had to be done to the PC.
                      The advantages of a custom ROM? Many, including having Play Store access through the tablet. The bargain tablets usually don't have it installed, because they don't want to pay Google big bucks to offer it. (Can't say as I blame 'em.) Custom ROM often remove the 'bloatware' many tablet makers put on there, making room for other apps you DO want, instead.
                      Right now, there is no firmware available from those who make the NextBook for the 7S model. That's the first thing Finless is doing to help us, in case we need to reflash back to stock for some reason.
                      If you REALLY want video chat over Skype, a tablet with a built-in camera would be the way to go. You MIGHT could add a camera to a 'Roid in USB host mode, but will Skype for ICS support such a configuration?
                      I, for one, am not going to bother to find out. Those who make the 'Roids have disgusted me to the point that I wouldn't take one now if they gave it to me.
                      I'm willing to install Skype to see if it'll work on the 7S, but I have no one to video chat with...
                      73 DE N4RPS
                      Rob
                        N4RPS, your backup.img is perfect. It unpacked no problems.
                        I will now make a STOCK ROM kit (none-rooted or anything) so you all have a stock ROM you can go back to if needed.
                          Great! Now you know why I do TWO of everything. If I had done only one or the other, it would have surely bombed!
                          Sounds like a plan to me!
                          73 DE N4RPS
                          Rob
                            I test flashed this on my Arnova and it boots!
                            So here is where to get the Stock ROM for the Nextbook 7P S Resistive screen.
                            http://www.freaktab.com/showthread.p...wich-STOCK-ROM
                              If my Big Lots has the Nextbook, should I take back the Polaroid and get the Nextbook instead? The Polaroid is semi-rooted I think and this one isn't. The main difference between the 2 seems to be the Nextbook has a camera and the Polaroid doesn't. They have a Sylvania for $69.99 which is a good deal but the Android on it is an older one. So I'm wondering if the Sylvania wouldn't be as good as the Nextbook or the Polaroid since the Android on it is something like 2.0 and the Nextbook and Polaroid have ICS on them? They do have some tablets advertised for $29.99 like a Sylvania, I think and a Pandigital. I'd be fearful of using those as my big main tablet cuz they have an older version of Android on them. Maybe 2.0 or something. They would be good to have as an extra tablet for e-reading and doing my Bible reading apps tho and not having to worry thaqt I'm overusing my main tablet. They also are gonna have the Polaroid for $89.99 so if they don't have the Nextbook I could take the Polaroid badck and then get it at a cheaper price. So far the Polaroid has been working well for me other than Google Play won't work on it. Looks for input as to whether to go with the Polaroid or the Nextbook. Knowing my Big Lots, they will be sold out of all tablets or either not get them in.
                              Tablets: Polaroid PMID 701i, PMID 4311, Zeki 10" tablet
                              "God Loves You"- Arlo Guthrie
                                Sylvania Tablet
                                Don't get the Syivania, it's battery is very small and won't last more than 2 hrs. I have the NextBook 7 (original) and plan to get the NextBook 7 S this Sunday, I had a Polaroid but took it back because it lost wifi every 2 minutes. I really liked the Polaroid but my Biglots never got anymore in. I have owned this NextBook 7 since December and really like it, of course I have Finless 1.5 rom on it and it never fails to run.
