HELP - MK809 III what firmware to use in this board to solve flickering/black screen
My HDMI-chip sounds similar to yours: Are you sure it isn't "IT66121" instead of "IT6121"? Perhaps you missed the "6"?
If we have the same HDMI-chip, it would make sense we both experience the same problem with the same firmwares, even though the other components are different.
MKMutual.
Yeah my bad i corrected it, also added the active chip (the small one on the cpu board side), don't know what that one does doh.
EDIT: Nevermind it's the power management chip
The problem is either related to the wifi driver (noticed that the firmware that you tried that didn't have wifi also didn't have flickering), the cpu T version or the hdmi...
If anyone else would post their specs with their success/or not with diferent firmwares it would help narrow down the problem for a specific driver or chip.
I'd say we have narrowed it down nicely, uha666. Everything, except the HDMI chip and CPU, is different on our devices - thus we must conclude the problem lays in the HDMI chip (which is not compatible with some firmwares) and not in any of the other chips.
Of course, a possibility could be that the RK3188-T chip doesn't work well together with the HDMI-chip using the roms from neomode.
It could be great if people experiencing the same problem would post their HDMI-chip names.
MKMutual.
Actually we have the same cpu, wifi, and hdmi chip =P
But i agree the problem must be in the hdmi chip, but the only way to test this is to find a stable rom and see if the hdmi driver or kernel is diferent between them. But i have yet to find a rom that works correctly at 720p in my case, i can't even find an original stock rom for my device since there are so many versions, the only thing i remember from it was that it said R-BOX on the rom description.
Have you tried NEOMODE HYBRID ROM 1.7? I will test it asap.
Another thing I was thinking; Could our sticks be suffering from static electricity? When we touch our sticks we don't use gloves as professionals do, thus we transfer the electricity we've been charged with onto the stick, where it will stay in the circuits.
I will try to take rubber-gloves on and a copper wire and decharge it by putting the copper wire into the ground and carefully try to hit all the circuits on the board with the copper wire. The reason I am suspecting this is due to the fact that I experienced a short period where I had no black-outs even in 1080P. Then it came back. But in the meantime, I had reset the dongle using the PC, where I had touched the board with my hands.
I don't know, but the issue is very irritating.
I will report back (tomorrow I might have a tight schedule, also saturday. Sunday I'm free though ).
I tried using a diferent hdmi cable and connecting the stick directly to the tv but still flickers. I just hope this is tv related and that i can never use the mk809 on this tv and have to go back to the mk808b i have in storage...
I have tested line one hundred of rom/kernel combination! No found a perfect solution... This are my results:
No flickering, perfect stable but NO OVERCLOCK only with Neomode 1.9a or 2.0 at 1080p!
Flickering/distorting problem (but NO SCREEN OFF ONLY BY CONNECTING DICERTLY TO HDMI PORT) with ANY OVERCLOCKED KERNEL (SAMKERNEL/Overclocked kernel with rkomatich) with ROM 2.1 or finless 1.6b or Hybrid 1.7! I have succesfully pushed to 1,9ghz cpu and ddr 800 ram... but flickering!
So my idea is: our GPU in Frequency Locked (I have to test it with dsmeg from terminal) and every time you push the cpu out of their stock frequency the image goes distorting... or maybe A BIG PROBLEM with our HDMI DRIVER....
Neomede WE NEED YOUR HELP!
P.S. Not a power problem! Now i'm using a 5V - 4A PSU! 20W TOTAL!
Do you get a stable device with 1.9a without overclock even if cable connected or only when connected directly to your tv?
I will do more thorough testings when I have time - 1080P (no overclocking) using Neomode 1.9a still has flicker - but it seems like it is only 60Hz. 50Hz works fine (until now). I do experience very bad performance in video playback though - streamed HD content all jitter. I get 10Mbps using speedtest, so it isn't a Wifi problem.
As said, I will do more testings later. But thanks for your input Gianca, I hope Neomode will comment in this thread soon.
How do I find the details about my Rockchip the way demonstrated above?
Just read the number on the chips of your board. If don't know wich chips are the corresponding ones just post a high res picture of both sides of the board without the heat sinks.
