Ugoos UM2
Originally posted by shenery View PostAnyone know of any ROMs that would fix the WiFi on a ugoos um2. Think its an rk3188 ap6210. Not sure if its the old or new WiFi version as I can't work out how to open the thing to see the serial number. This WiFi is driving me crazy
right now I'm using
NEOMODE CUSTOM ROM MK809III AP6210Version 1.9a with kernel2.img
everything working smooth and fast, no problem with Wifi so far..
Try to change the kernel, for me kernel2.img works good..
also if nothing work from above, Helo!! we got ''KitKat'' Android 4.4 KitKat Firmware by Finless Bob posted
on 20/01/2014
ugoos.net-Chromecast with Google TV
- Android Q Android 10
Originally posted by more2read View PostI just received a couple UM2 units, and so far so good running stock firmware.
What is the issue with Wifi - low signal, drop-outs?
So far, this has been a fun unit to play with - the kids love the Remote Control App and Wifi display.
Cheers
I now have perfect WiFi using neomodes ROM mentioned above. In using kernel 3 but kernel 2 works also. Problem now is i can't get any video to play smoothly. Anyone any idea what i can do to fix video?
Originally posted by more2read View PostWhatp are you using to play video?
Are you playing from ldocal SD Card / USB, Local Network, Internet?
Hello all,
I have tried a few ROMS also on my UM2. Its a good stick but I don't seem to find the right solution.
Want to use it basically as a XBMC Station.
A few days ago I tried this one: http://www.freaktab.com/showthread.p...sion-2-0-1080p
With this result:
So the HDMI Signal in HD is not working. Next to a very poor WLAN performance.
Not to mention the original IR remote is not working either.
I also contacted Ugoos directly. Became an answer the very next day. It seems they are working on a new ROM. But no informaiton whatsoever about release date or any other detail.
Has anyone a recommendation for me?
Regards
C
There are currently 1931 users online. 0 members and 1931 guests.
