Help me unbricking my tab
Hi,first of all sry about my english.2 month ago i buyed a tab(allview city life) and now i rooted the tab.Root went well but i installed ChainFire 3D and i installed the driver and then the device reboted but now it brick(softbrick).I search hours and hours and hours but i didn't find a solution to this problem.How i can unbrick my tab?(i rooted it whit a program called Motochoper)Tags: None
Originally posted by bin90000 View PostHi,first of all sry about my english.2 month ago i buyed a tab(allview city life) and now i rooted the tab.Root went well but i installed ChainFire 3D and i installed the driver and then the device reboted but now it brick(softbrick).I search hours and hours and hours but i didn't find a solution to this problem.How i can unbrick my tab?(i rooted it whit a program called Motochoper)
see if you can find the firmware for your tab and we'll move on from therefreaktab art developerif you like my work please buy me a pepsi
Originally posted by tattman65 View Postyou may have to find the original rom , did you install a recovery ? or just root ?
Originally posted by bin90000 View Posti just install the root.i found the original firmware http://forum.yarvik.com/forum/gotab-...sandwich-stock.
there are two different numbers on the firmware build so we need to know for sure which one ok .
we'll try our best to help ok .freaktab art developerif you like my work please buy me a pepsi
Originally posted by tattman65 View Postthere are two different numbers on the firmware build so we need to know for sure which one ok .
we'll try our best to help ok .) http://www.yarvik.com/userfiles/yarv.../TAB462EUK.zip
Originally posted by bin90000 View PostSorry,i found the original one(4.0.4 ice cream) http://www.yarvik.com/userfiles/yarv.../TAB462EUK.zip
ok good, just hold tight everyones kinda busyfreaktab art developerif you like my work please buy me a pepsi
and after that its like you just bought it.if you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
Originally posted by snakekiller View Postnow you can flash this with yarviksflashtool.
I connected the device,started in recovery mode>apply update from ADB>selected the image>sysupdate,but it doesnt know my device.
The bad news it's that the tab it's bricked, the good news it's that, if you say it's charging when you plug in charger, it is only a soft brick so you can try this;
-you will work blind (you won't see nothing on display during this)
-let the tab charge for few hours to be sure it's more then half charged
-I m sure you have the flashing tool from here http://forum.yarvik.com/showthread.p...ndwich-(STOCK) and the divers and the firmware official
-after charging, unplug charger and be sure that the light from right side (next to charger slot) is OFF
-If the light is not off, press the POWER button until it switches OFF
-press the VOLUME DOWN button of your tablet and keep holding it.
-While holding the button VOLUME DOWN, connect the USB cable (the one provided with your tablet) to your tablet and to your PC.
-After you have plugged in the cable, and while still holding the VOLUME DOWN button, quickly press the POWER BUTTON for 6 times rapidly after each other, then release all buttons.
-Windows will now attempt to recognize the connected tablet but will fail to install its own driver if you don't have the driver installed, if you previously flashed a firmware on this Tab you most probably will see device connected.
For further help I need you to tell me if your PC recognize the tablet on this step.
</form>
1.my volume up/down buttons are virtual(i only have the home/power buttons)
2.I tried to hold the home button then i connected the usb to pc and then i pressed 6 times the power button but didn't work(you said the windows will try to recognize the tablet but nothing show up)
2g
Did you tried another USB cable or USB port?
Verstuurd vanaf mijn V370 met Tapatalkif you love my work please buy a coffee
</form>
Originally posted by snakekiller View PostDid you tried another USB cable or USB port?
Originally posted by bin90000 View PostI tried but it didnt worked.I see something when i open the tab(allview city life usb driver in driver manager),i tried to unistall the driver but didn't work.This is a photo of the drivers if it help http://snag.gy/Yt9iZ.jpg
hey buddy, snakekiller is the yarvik guy around here . i'm sure he'll come up with something for you .
just hang onfreaktab art developerif you like my work please buy me a pepsi
May I ask you witch tablet is yours tab462EUK or tab462EUK ZANIA 10 tablet or are these the same?
</form>
There are currently 4353 users online. 1 members and 4352 guests.
