I have red somewhere saying that i need to miss around with the file playercorefactory.xml and edit the rules to reflect the new external player I have and i did I am attaching a copy of the playercorefactory.xml file i am using now please have a look at it and let me know what things i'm doing wrong in it so i can fix that error.
after revising the playercorefactory.xml file i pasted it in the /userdata folder using the built in File explorer in jynxbox M6 the box asked me to overwire the current one and i pressed yes but still have same error when i try to view arabic channels . i added the arabic repo from xbmchub using the option install from zip and Fusion as a source and the source downloaded fine and i made sure that the add-on was enabled as well . so when i view the arabic channels i get the external player active error message and then when i press ok the stream stops .
the reason i am using external MX Player Pro 1.7.22 + ARM7 Codec is because my device is a Neon device and i want to utilize the Hardware Accelaration instead off the sofware acceleration.
when i open icefilm and try to view a move the move launches great with no lagging or choppy picture its running smooth with synced audio, its very sharp picture also no buffering issue when viewing 1080P movies. I am mainly having issues with arabic channels using variety of arabic Repos like 1Channel and much more .
I also want to know how do you reboot the jynxbox M6 without cycling the power adapter?? any key combonation do i have to press on the remote control??
and last but not least, when I uninstall certain apps that came with my Jynxbox like (facebook,skype,xbmc,globe news)... and cycle the power from the back the system reload them again a window pops up after the android logo saying installing 0/4 and it loads the app i uninstalled how can i get around that??
looking forward to hear from you as soon as possible.
cheers
Charlie
