UPDATED! - MX2 ROM talk - MX2 BETA ROM 1.1 ready
Sorry guys I have been too damn busy the last few days. I will get to it. And no it doesn't have a hardware check. I left the assertion check in the edify script that installs the ROM. It checks build.prop and needs to be a certain thing. Easy to remove.
OK new beta 1.1 ROM is uploading now. I also found a bug in my AML auto script that is probably why some never saw recovery do anything
I removed the assertion script so this should install on ANYTHING so be careful. I am not flashing your bootloader so you should not hard brick.
Should be up in about an hour.
Beta 1.1 READY!
UPDATED Feb 11 2014.
I have fixed some things in the BETA ROM.
I removed any assertion checks for a device.
I fixed AML auto script so it should work.
ROM download is updated to BETA 1.1
Here is the download!
ROM -> MX-2 Finless ROM, BETA 1.1 (233 megs)
Let me know!
Let me know!
WiFi is not working.Live as if you were to die tomorrow. Learn as if you were to live forever
No Internal Storage Left
Finless Bob!
Thanks so much for turning your attention to these MX2 boxes. I've used on of your ROMs on a Minix X5 and truly appreciate the great work you do.
I tried this ROM on y MX2 clone, after having used the ROM at this post to make it compatible with Matricom updates: http://forum.xda-developers.com/showpost...stcount=12
Unfortunately, whether I use the Matricom 1.16 ROM or your ROM from this thread, the box always shows zero internal memory remaining. Do you have any clue as to why this might be, or what I might do to fix it?
thanks,
Boni
Re: UPDATED! - MX2 ROM talk - MX2 BETA ROM 1.1 ready
Originally posted by rnf View PostThanks for taking the time to work on this unit. You do great work!
Has anyone tested the BETA version yet?
Sent from my SM-N9005 using Tapatalk 2Live as if you were to die tomorrow. Learn as if you were to live forever
First I would like to thank you for this rom.
I need a favor from anyone here, I modified the mx 2 firmware by just adding more apps to be installed when the room is installed. Now I have the rom folder and need to zip it so I can install it on my units.
I was looking for signapk for the midnight mx but couldn't find anything.
Can anyone please provide me a tool to repack the firmware.
Thanks in advance
Originally posted by tvguy View PostFirst I would like to thank you for this rom.
Thanks in advance
Originally posted by fatfreddiescat View PostHi Bob, I jaust tried this ROM on a generic MX2, I got as far as choosing launcher but the only button on my remote that worked was the power button.
Please try this. Flash your ROM that works with your remote.
Then using ES File explorer copy out the remote.conf from /etc
Now flash my ROM and copy that file into /etc replacing the one in my ROM.
If that works for you I will make a simple small update.zip to add that file to my ROM for others.
There are currently 2080 users online. 7 members and 2073 guests.
