can you do this on a flash drive instead or does this only work on a sd card
How to cache to External SDcard speed up video buffering, faster and smoother video streaming.
Originally posted by Joecap View Postcan you do this on a flash drive instead or does this only work on a sd card
Update to my original post with better app called "foldermount"
Ok, since I can't edit my original post, here is my update on the process, due to the instability of the "External 2 Internal" app, I have found another app called "Foldermount" which is very stable and working well.
Hi all,
After an extensive search for the answer for the below issues, I believe I found the solutions:
a) Commoncache error if attempted to edit Advancedsettings.xml file to do path substitution to SDcard
b) Long buffering while watching movies, specially 720/1080 movies.
c) Looking for faster and smoother video streaming playback
d) cache loads faster when try to click on "date release", "new movies", "all 720 movies" etc...
e) Cache full message after buffering.
Solution (More simplify and a lot eaier to setup)
** Make sure you buy a class 10 high speed card (30mb/sec) and FORMAT with ext4 or FAT32(fat32 is slower than ext4 but it should works fine too). Also you must startup xbmc at least once in order to create xbmc folder, then do all your setup once done shutdown xbmc then proceed below:
1) Format your SDCard
Download Fat32formatter from here http://fat32-formatter.softwareandgames.com/ and use it to format your sdcard. (your sdcard will be your normal storage and for xbmc caching.
2) Create XBMC cache folder on the external SD Card):
Use ES file explore or Root browser and navigate to
/mnt/external_sd folder, then create a new folder and name it what ever you want, I named "XBMC_cache", without quote.(this folder will hold all the xbmc movie cache).
3) Map your XBMC cache folder to the external SD Card (Only the cache folder required)
Download an app called "Foldermount", launch the app, tab on the "+" icon to add pair. You will be prompt for the following options and you need to fill in:
a) Give the mapping a name, I called it XBMC_data_mapping"
b) Provide the path to the original xbmc data cache folder: /data/data/name of the xbmc folder (the name depended on what version of your xbmc you are using. For beyond XBMC, it called com.flumster.xbmc. So source path should look like this /data/data/com.flumster.xbmc
c) Provide the path to the destination folder on the SD Card: /mnt/external_sd/xbmc_cache (this folder I created previously), then tab on the check mark at the top right to save.
d) Once done, tab on the PIN icon, it will turn green, meaning it successfully mapped.(if not turn green, tab again)
4) Configure your XBMC to have unlimited caching - the entire movie!
a) If you are using Advancedsettings.xml file, which located in /sdcard/Android/data/com.flumster.xbmc (I'm using beyond xbmc) make a backup.
b) Install xbmctalk maintenance program from Xunitytalk. After installed you should see it under PROGRAMS. Launch this, select "xbmctalk TWEAKS", then select "Add 0 cache Advanced XML". This will create a new Advancedsettings.xml file.
Reboot your device and enjoy smoother, faster movie play back by caching the entire movie to your external SD card.
If you have any question, please don't hesitate to ask. My XBMC is really acting like playing a physical DVD, which is no more buffering, stuttering.Last edited by buhohitr; 27 February 2014, 23:35.
Guest
Works great..... Thanks for sharing.
Startup time of Xbmc is a fraction slower "preparing first run" 0,5 second.
But no buffer stutter again....!!
Originally posted by buhohitr View PostOk, since I can't edit my original post, here is my update on the process, due to the instability of the "External 2 Internal" app, I have found another app called "Foldermount" which is very stable and working well.
Hi all,
I am trying to do the above, but with JustXBMC and i could do with some help as i don't know where the original cache file is for JustXBMC so i can re-map it using foldermount.
Many thanks
Steve
It is necesary to move the entire xbmc folder?
Hi, thanks for your recommendation and instructions. I can confirm that it works very well, but I have some questions. You recommend moving the entire XBMC folder. Is it necessary? Do not you think it could be just enough to move the cache folder?, What are the advantages between moving the entire folder and only the cache pne? BTW where is located the cache folder in beyondxbmc?
Originally posted by buhohitr View PostEven you point to the root folder but only the cache folder is moved. This done by advance settings.XML file. You only want the cache folder move.
Sent from my Galaxy Nexus using Tapatalk
One last thing, what is the location of XBMC video cache?
Edit 1: I'm sure mount folder does its work, I have checked and the folders links are right (it shows the folder when it is supposed to be), but XBMC doesn't open. I've tried with another version of XBMC and even from a different destination (I've tried on an sd card and on a 3tb HDD) but the app doesn't open.
This tutorial says I need to have a class 10 SD Card in order to make it work. That's not my case and I don't know if that's the reason why the process is not complete.Last edited by jsegovia612; 03 September 2014, 18:51.
Re: How to cache to External SDcard speed up video buffering, faster and smoother video streaming.
Originally posted by jsegovia612 View PostHi, thanks for this tutorial. I'm trying to do it but after turning the tab green, my XBMC doesn't open. I tried several ways to do it but it doesn't work. It always asks me if I want to copy the files to the destination. Is this necessary? By the way I'm using XBMC Minix Edition.
Originally posted by buhohitr View PostNo, any sdcard should work if your device can see the card. Here is the process. You need to open xbmc at least once, the reboot your device to make sure xbmc is closed completely. Now install foldermount and pick xbmc directory (com.xbmc.org....), pick source and let the app pick the destination folder if you don't want to create your own. When ask to move file or over write directory, answer yes. Once done, when you enable, the pin should turn green, Now open xbmc, it should work. Your device must have root. When you reboot the device, you have to wait 30sec for the card to mount, you should see a message about the folder has mount successfully. By the way, you also need to set up "unlimited caching for your xbmc using advancesettings.xml
1.- When I paste the folders to have my previous configuration, XBMC doesn't open. I tried several times but it was impossible.
2.- The only way for XBMC to work implies having no folders, not in source or in destination. I'm starting to configurate a new setup but the system doesn't create its folders. If I manually create or paste just one folder in source or destination, Xbmc doesn't open. And it is going to be okay for playing movies and tv shows, but customization is going to be impossible (no libraries or super favourites, no bookmarks and stuff).
Please help me. Tell me if you have a full operative XBMC or have the same problem.
Edit: If I link the system XBMC folder (source) with my previous configuration folders (destination) XBMC doesn't open, but I'm sure it is right because I can see the sd card folders in the internal storage locationLast edited by jsegovia612; 04 September 2014, 05:10.
There are currently 1893 users online. 1 members and 1892 guests.
