wifi issues
If you flashed the device, you probably put a firmware on it isn't compatible with the wifi chip.
You can try to identify your device from here: http://www.freaktab.com/showthread.p...-identify-them
If it isn't the original (genuine) MK808, then you must find someone who has shared the correct firmware for your clone.
Originally posted by Bueno View PostIf you flashed the device, you probably put a firmware on it isn't compatible with the wifi chip.
If you didn't flash it, then it should've had the correct firmware on it. Did someone else own the device before you?
Here is something else to consider:
Hey, I just read all these replies and couldnt fix my issue, I messaged my brother and he reminded me that "easy battery saver" app, among others similar usually have a network control option that automatically enables toggling of your network via the recommended install options of easy battery saver.
Try checking all your apps and internal battery saver options.
Originally posted by Bueno View PostIf you didn't flash it, then it should've had the correct firmware on it. Did someone else own the device before you?
Originally posted by jennywren View Postthey dont know what software they used
I think you need to check the other side of it to identify it better.
Maybe post pictures in the clone thread for better help.
Originally posted by Bueno View PostYou can try to compare your device to some of the pictures in this thread http://www.freaktab.com/showthread.p...-identify-them
Originally posted by jennywren View Postplug my device in start flass tool but not picking up my device
Like rdsok said, you shouldn't flash the firmware until you've identified whether or not you have an original or clone device.
There are currently 2517 users online. 0 members and 2517 guests.
