CX-919 Flickering
I flashed my CX-919 with this ROM http://www.freak-tab.de/neomode/ncr19a_mk809.zip
see more here http://www.freaktab.com/showthread.p...0-Version-1-9a
Fixed all my problems.
Hope it helps
Someone help me about how to make my computer recognize my CX-919?
I've been tried on many O.S., such as Ubuntu, Win8, Win7, WinVista and even WinXP, but does not work.
I follow the steps, press Fn button before plug the stick on PC and when I try to install the driver (on Windows) through the device manager, I get a message saying that driver already on newer version. But, mx CX-919 stiil not recognized.
What I should to do? Any idea?
Originally posted by tonysacanix View PostSomeone help me about how to make my computer recognize my CX-919?
or hear http://www.mediafire.com/download/yq...ckusb_v3.5.rarPlease consider making a Donation to freakTab
Originally posted by blinkone View PostHave you tried installing the drivers with RK_DriverAssitant.zip tool http://www.cnx-software.com/2013/11/...-windows-xp78/
I'm starting to regret of this order. =/
Cause the video performance is poor (a bit slower) and can't update the firmware.
Another clue?
Originally posted by tonysacanix View PostYeap, I tried this one too. I got the success instalation message, but when I plug the stick, it still as unknown device.
Another clue?Please consider making a Donation to freakTab
Originally posted by tonysacanix View PostNo, I'm using OTG port at the opposite side of wifi athena.Please consider making a Donation to freakTab
Originally posted by tonysacanix View PostWhat a crapy mistake of project. The OTG port is the one that is wrote DC.
Ok, I'll try the end port.
Thanks.
If you still have no luck..
i would normaly say its the driver its not installed correct but i see you have tryed many opperating systems so i dought you have installed the driver wrong every time on every opperating system so im thinking its something else might be the problem.have you tried another OTG lead,,,The fn button might be broke try shorting the connections on the bored that go to the fn button,other than that you could try shorting pins 6&7/7&8 or it could be 8&9 on the nand chipLast edited by blinkone; 13 October 2014, 23:18.Please consider making a Donation to freakTab
Originally posted by blinkone View PostIts printed on the case wrong...Good luck I hope you can do it now.All other tv sticks it is the side port but not the cx 919. the cx 919 OTG is the end port im 100% sure.
In my case, the OTG port is really on the side and I dont think the Fn button can be broken. Because, when I plug on the end port nothing happened, but when I plug on the side port the computer recognize the stick as unknown device.
I've been figure out what is wrong, but I dont know what can be.
- I did make sure to download the correct driver from this page http://www.rockchip.nl/downloads/ (win8 64bits in this case)
- I press Fn and then plug the stick on the computer
- I try install the driver and when it's starts Windows shows me the message: "The better driver software for the device is already installed"
What I can be doing wrong yet?
I just discovered in other thread that my stick is a CX-919 clone and purposely the flash mode was disabled on hardware. That can be viewed here: http://www.freaktab.com/showthread.p...-rooting/page4
The good news, there is a way to enable it by soldering. And I'll try it out.
Thanks for helping.
CX919 clone
Hello. My cx919 stick clone . How to stock rom ? http://www.freaktab.com/showthread.p...-Help&p=235853
There are currently 1883 users online. 1 members and 1882 guests.
