XBMC Backup/Restore App!
    Great backup app. Will you be updating it for use with Kodi?
      I will, but not just yet.
      Probably next month or so.
      Everything is possible if we work together!
      ApkFreak
        Great app...will you be able to make it compatible to SPMC as well ..at the moment it can only back up and restore through gotham xbmc..would be very nice if it can support the 3 versions of xbmc..namely ..xbmc gotham..kodi..spmc...thanks....thank you again..
          XBMC backup/restore app
          I have an APK editor and have been trying to edit your great app to work with Kodi but to be honest I haven't got a clue. I have managed to change all the names to Kodi but thats as far as I have got. Could you possibly tell me what I would need to edit to make it work please. I am assuming I need to find where it says XBMC and change the name to Kodi but I am just guessing.
          Any help would be much appreciated because I love your app and want to update to Kodi.
            Im working on Kodi ver.
            Relise soon
            ApkFreak
              First post updated with KODI version.
              AMLogic and Rockchip Support
              Have Fun
              ApkFreak
                I'm using the app to backup Helix works good. I tried to backup to USB but get the message "Error:NoStorage" am I doing something wrong? I tried reformatting the USB to different formats but nothing worked. I am using an OUYA.
                  Ouya have difreant path to USB storage than amlogic and rockchip devices. So it will need some changes in the app.
                  ApkFreak
                    Only works with official helix build, if by any chance you can make one for spmc 14.1 it would be much appreciated ,thanks @lewy20041..thanks again...iam using amlogic M8N and M8S...thanks..
                      It's a great idea. Only problem I have found is that it is pretty hit and miss on what it backs up and restores. Sometime a got an empty corrupted zip at the end sometimes it was a zip missing the addons folder. Regarding restores, sometimes it restored no problem and sometimes it restored missing the userdata folder for example.
                      Backing up to the cloud would be a great feature to have as well.
                        Have Fun
                        Great thanks where can I download it?
                          post #1...where it says download ........
                            HELLO ,lewy20014 hopefully you can create one for use with spmc helix as well ,,thank you very much for your work,,very handy if it can support both kodi and spmc helix builds..thank you again..
                              This is some great app Lewy. Plain and simple. Just what I need.
                                Hi Lewy. Could it be an extermal sdcard is not recognized on an AMlogic box? I don't see an an option to backup to an externale sdcard.
