I'll post both the kernel download link and the overclockomatic source file that i used to produce that specific kernel, and you'll find a lite guide to use it by yourself in the next post. Now some advice:
- BE CAREFUL! If you are not sure to overclock your stick at the maximum frequencies allowed, set the max cpu frequency at some step lower (with apps like No-frills or SetCPU) and step up gradually, doing some test earlier
- Use a powerful power supply unit! I noticed that a lot of flickering and/or rebooting problems are caused by insufficient power feed, my advice for testing is this: Link your stick to a PC's USB (better if USB 3.0) or link it to TWO power sources, using both the power input and the OTG input, but if you have a 3A or more PSU it should work flawlessly (i'm waiting for mine to arrive, so i can only suppose as of now).
When you have done with testing, if you want to use it this way, try with an HDD attached to the OTG port, and see what happens.
- Use always the rkbatchtool contained into the package of the ROM that is the destination of the kernel: If you are using the 1.9a ROM, open the 1.9a .zip and use the rktool contained there, the same for 2.0, 2.1, etc.
When you are going to flash, check only the box of the kernel partition and insert the right path to the .img kernel file!
- If not specified, if you want to change the resolution between 1080p and 720p you'll have to do it into the stick's settings, default is usually 720p
- All kernels will be for AP6210
Ok, let's stop talking, and do some overclocking
- Neomode 2.1 beta ROM:
Link to the rom: Download
Kernel - CPU 1920 GPU 798 RAM 800 : Download
(frequency steps are 1008,1200,1416,1608,1704,1800,1920) Stable up to 1800, Unstable at 1920
Overclockomatic: Download
- Neomode 2.0 ROM:
ATTENTION:
The best full working kernel as of now is the one contained into the ROM, but since it has some clock problems, it is locked to 1.6 GHz, for better benchmark results and/or speed improvement use the kernel down there, but remember that it has no Wi-Fi and is pretty unstable, be careful then, it's for knowleedge only, use it only if you are desperate! I've told you!
Kernel NO WI-FI: Download
(frequency steps are 1200,1416,1800) looks stable at 1800, avoid Wi-Fi settings.
- Neomode 1.9a ROM:
Kernel - CPU 1416 GPU 466 RAM 466 - 720p: Download
(frequency steps are 1008,1200,1416) fixed choppy video
Kernel - CPU 1416 GPU 798 RAM 800 - 1080p: Download
- Neomode 1.7 ROM:
Kernel: Coming Soon
Overclockomatic: Coming Soon
- BONUS STUFF:
I have made a simple batch tool to use overclockomatic without opening cmd and inserting folders all the time: you will have only to drag and drop the overclockomatic source and then the kernel you want to patch, the patched kernels will be saved into orignal kernel's folder.
- PERL needed
Tool Download
- More ROMs are coming!
