Anyone know what pins I have to short to unbrick this?
Originally posted by shenery View PostPlease consider making a Donation to freakTab
Originally posted by blinkone View PostOHHH I did not expect to see that im not sure then your nand chip should look like this in post 34 its the chip with the sticker on in the photo http://www.freaktab.com/showthread.p...479#post144479
Is that the ones marked blue in this diagram?
Cheers
Steven
Cheers
Steven
The fix
Right i managed to fix it by shorting pins 7 and 8 i think. I had to short pins 7 and 8 whilst plugging in the male to male from device to pc and plugging in the mains power cable all at the same time. i had to get my girlfriend to help me as its a lot to do at the one time. Also took me a couple of attempts.
You have to take off the metal shield on the back that covers a couple of chips. I did this by using some nail clippers. Once its off you should see the image below.
Pins 7 and 8 are marked in red.
So all you have to do is short those pins with a pin or something whilst plugging in the male to male in the pc and plug in the power cable and you should be sorted.
Little tip always clear idb before installing a new rom and you will have less chance of bricking it again.
Cheers
Steven
There are currently 2943 users online. 0 members and 2943 guests.
