Android 4.2.2 for Measy U4K
    If I really wanted to tease you I think I could get a KK build working too! But without a test device it would take way to many test uploads
    Donate to Finless
      19955 with some app running in the background. Excellent, just as cs918s.
      I'm so sorry for your stick, mate
      EDIT did you try to revive it? Maybe there is something to do with shortening processor pins to reset cache the way they did with rk chips. It does not seem that you could grill it while booting up. So it's worth to try. Just look how they did it in rk3066 forum.
      As for KK, let's hope they'd come up with KK for cs918s. Then we know what to do
        Thank you very much!!!
        I appreciate you!!! Thank you very much!!!!
        (I just register this site to write this comment.)
        Originally posted by d33 View Post
        The final solution is thanks to a tool built by "LOLET" on XDA forums, I had worked out what needed changing but couldn't rebuild the CRC for the file.
        ADD - Can you provide Antutu test results for the record.
        Bitterly sad my TV stick didn't survive to live free and fast :-/
          Re. My U4K - I binned it I've got two RK3188 sticks and a tablet with a second RK3188 tablet and an A31 tablet on the way. More than enough to keep me busy
          Re. KK I had it booting but not quite working (and obviously missing wifi ) - I think I was nearly there!
          Donate to Finless
            How about 1080p version of this fw? Do you plan to give it a try?
            Just read your exchange with lolet on xda. Sweet that he offered his tool.
              Remind me next week on 1080p
              Agree very good of Lolet to share. When people share the ripple benefits many especially when the ripple turns into a wave with the additional contributions of others
              Using my ipad so apols for any stupid ios spelling 'corrections'
              Donate to Finless
                Memory of
                Hi, can someone tell me why at Settings->Storage appear 2.00GB Total space for APK Installation space and only 3.05GB Total space instead of 8.00 GB at Internal storage like in speciffication?
                  There's a problem with lolet's tool and I can't find the right byte to patch manually. If he responds on xda I'll do 1080
                  Donate to Finless
                    Ok, waiting for the news.
                      Memory unavailable on Measy U4K ?
                      Maybe is a problem with fw?
                        I can not upgrade ...
                        Hello people.
                        When I try to upgrade using the "short pins" method nothing happens.
                        My U4K boots normally.
                        Any suggestions?
                        Regards.
                          Originally posted by Marginal View Post
                          Hello people.
                          Any suggestions?
                          Regards.
                          As I can see you want to upgrade from sd card. Reburn image and retry. What fw is actually installed on the stick?
                            Steps to upgrade Measy U4K
                            Hello people.
                            Any suggestions?
                            Regards.
                            The steps are:
                            1. Power off the Measy U4K
                            2. Put the fw on sdcard or load fw with PhoenyxSuit;
                            3. Short the pins and power on through computer USB where Phoenixsuit is installed.
                            4. Release the pins.
                            5. The update will start automatically.
                            I hope you understand.
                            Please tell me how much memory report your Measy U4K?
                              Regarding the use of the 8Gb NAND. The firmware we are using is from a 16Gb device which may have something to do with it?
                              The partition table used is:
                              ; ˵Ã÷£º ½Å±¾ÖеÄ×Ö·û´®Çø·Ö´óСд£¬Óû§¿ÉÒÔÐÞ¸Ä"="ºóÃæµÄÊýÖ µ£¬µ«ÊDz»ÒªÐÞ¸ÄÇ°ÃæµÄ×Ö·û´®
                              ; ¹Ì¼þÏÂÔØ²ÎÊýÅäÖÃ
                              ; mbrµÄ´óС, ÒÔKbyteΪµ¥Î»
                              [mbr]
                              size = 16384
                              ; ·ÖÇøÅäÖÃ
                              ; partition ¶¨Òå·¶Àý:
                              ; [partition] ; //±íʾÊÇÒ»¸ö·ÖÇø
                              ; name = USERFS2 ; //·ÖÇøÃû³Æ
                              ; size = 16384 ; //·ÖÇø´óС µ¥Î»: ÉÈÇø.·ÖÇø±íʾ¸öÊý×î¶à2^31 * 512 = 2T
                              ; downloadfile = "123.fex" ; //ÏÂÔØÎļþµÄ·¾¶ºÍÃû³Æ£¬¿ÉÒÔʹÓÃÏà¶Ô·¾¶£¬Ïà¶ÔÊÇÖ¸Ïà ¶ÔÓÚimage.cfgÎļþËùÔÚ·ÖÇø¡£Ò²¿ÉÒÔʹÓþø¶Ô·¾¶
                              ; keydata = 1 ; //˽ÓÐÊý¾Ý·ÖÇø£¬ÖØÐÂÁ¿²úÊý¾Ý½«²»¶ªÊ§
                              ; encrypt = 1 ; //²ÉÓüÓÃÜ·½Ê½ÉÕ¼£¬½«ÌṩÊý¾Ý¼ÓÃÜ£¬µ«ËðʧÉÕ¼ËÙ¶È
                              ; user_type = ? ; //˽ÓÐÓ÷¨
                              ; verify = 1 ; //ÒªÇóÁ¿²úÍê³ÉºóУÑéÊÇ·ñÕýÈ·
                              ; ×¢£º1¡¢nameΨһ, ²»ÔÊÐíͬÃû
                              ; 2¡¢name×î´ó12¸ö×Ö·û
                              ; 3¡¢size = 0, ½«´´½¨Ò»¸öÎÞ´óСµÄ¿Õ·ÖÇø
                              ; 4¡¢ÎªÁ˰²È«ºÍЧÂÊ¿¼ÂÇ£¬·ÖÇø´óС×îºÃ±£Ö¤Îª16M×Ö½ÚµÄ ÕûÊý±¶
                              [partition_start]
                              ;------------------------------>mmcblk0p2/nanda
                              [partition]
                              name = bootloader
                              size = 32768
                              downloadfile = "bootloader.fex"
                              user_type = 0xC000
                              ;------------------------------>mmcblk0p5/nandb
                              [partition]
                              name = env
                              size = 32768
                              downloadfile = "env.fex"
                              user_type = 0xC000
                              ;------------------------------>mmcblk0p6/nandc
                              [partition]
                              name = boot
                              size = 32768
                              downloadfile = "boot.fex"
                              user_type = 0xC000
                              ;------------------------------>mmcblk0p7/nandd
                              [partition]
                              name = system
                              size = 1572864
                              user_type = 0xC000
                              downloadfile = "system.fex"
                              ;------------------------------>mmcblk0p8/nande
                              [partition]
                              name = data
                              size = 4194304
                              user_type = 0xC000
                              ;------------------------------>mmcblk0p9/nandf
                              [partition]
                              name = misc
                              size = 32768
                              user_type = 0xC000
                              ;------------------------------>mmcblk0p10/nandg
                              [partition]
                              name = recovery
                              size = 65536
                              downloadfile = "recovery.fex"
                              user_type = 0xC000
                              ;------------------------------>mmcblk0p11/nandh
                              [partition]
                              name = cache
                              size = 1048576
                              user_type = 0xC000
                              ;------------------------------>nandi, private partition
                              [partition]
                              name = private
                              size = 32768
                              keydata = 1
                              user_type = 0xC000
                              ;------------------------------>nandj, data image backup
                              [partition]
                              name = databk
                              size = 262144
                              user_type = 0xC000
                              ;------------------------------>nandk, UDISK
                              [partition]
                              name = UDISK
                              downloadfile = "diskfs.fex"
                              ;verify = 0
                              Donate to Finless
                                Reading that:
                                Apparently the sizes are in sectors and a sector = 512 Bytes
                                mmcblk0p2/nanda = 16K
                                mmcblk0p5/nandb = 16k
                                mmcblk0p6/nandc = 16k
                                mmcblk0p7/nandd = 0.75 GB (/System)
                                mmcblk0p8/nande = 2 Gb (/data)
                                mmcblk0p9/nandf = 16k
                                mmcblk0p10/nandg = 32k (recovery)
                                mmcblk0p11/nandh = 0.5Gb (/cache)
                                nandi = 16k
                                nandj = 128 Kb
                                nandk = the rest (should be ~4.5Gb for 8Gb device) (/sdcard)
                                Suggest you print the sizes you have using df -s
                                Donate to Finless
