Android 4.2.2 for Measy U4K
    Originally posted by ADD View Post
    Hey Dee!
    Good news! I'm in. Please use the stock fw CS918S dowloadable here
    http://www.mediafire.com/download/eh..._20131202_.rar
    Hello.
    I downloaded the FW, but it asks for a password in order to be able to unrar.
    Thanks.
      That's the stock firmware! Download from temp link in first post
      Donate to Finless
        This is the stock fw for cs918s. If you flash this on u4k you'll have no wifi/bt. Use the link in the end of the first post instead.
          Stick does not connect ...
          Hello.
          One last question (I hope :-) ).
          When I try to upgrade, the stick gets connected for a couple of seconds and then disconnects.
          On the driver installation window there's a message:
          "MTP USB Device
          Device Unplugged"
          Presently on the U4K I have the 4.2.2. with no WiFI.
            Originally posted by Marginal View Post
            Hello.
            "MTP USB Device
            Device Unplugged"
            Shorten the pins and connect to pc. Then release pins. You should hear the windows sound that the divice was recognised. Only then Phoenix starts flashing. So, prior to connecting first thing to do is to browse to the firmware file.
              Originally posted by mirceatm View Post
              The steps are:
              1. Power off the Measy U4K
              2. Put the fw on sdcard or load fw with PhoenyxSuit;
              3. Short the pins and power on through computer USB where Phoenixsuit is installed.
              4. Release the pins.
              5. The update will start automatically.
              I hope you understand.
              Please tell me how much memory report your Measy U4K?
              Thank you all :-).
              It says 2 GB internal memory ...
              Regards.
                To get a true picture of storage usage you need to use df at the command line
                Donate to Finless
                  No more WiFI ...
                  WiFi went dead ...
                    WiFi went dead ...
                    Just reboot.
                      Just reboot.
                      I did, it works and then same thing happens.
                      Is it me, or this is a bug?
                      Thanks.
                        Must be your router then. Try to play with channels. Then change the bandwith to 20 instead of 40. Usually it's more stable.
                          I will.
                          The strangest thing is, I have changed nothing in my router's settings, and before the FW upgrade I had no such problem.
                          Thanks.
                          Both my 2.4 & 5 GHz settings were @ 40 MHz ...
                            Originally posted by Taajan
                            Can some one repost the Rom please. Want to install it on my CS918S.The original link does not work.
                            I've updated the link on the OP.
                            Donate to Finless
                              Did you see there is an update to the latest stock firmware cor CS918S?
                              Check the title - this is U4K
                              Donate to Finless
                                Thank you d33!
